turbo ls1.. wheres the power
Old Dec 21, 2010 | 01:33 PM
  #31
jts gto's Avatar
That would be great. Then I can just order the inevetable 13#
Old Dec 21, 2010 | 01:34 PM
  #32
jts gto's Avatar
Hows your new setup treating you charcold?
Old Dec 21, 2010 | 02:48 PM
  #33
mmarlow21's Avatar
run the dyno with something besides those heavy 20in wheels
Old Dec 21, 2010 | 05:14 PM
  #34
454navyss's Avatar
04stepside (i think thats his SN) has a turbo truck and makes less than 400rwhp on a dyno but his truck is a MONSTER on the highway, some of the DFW guys can vouch for that
Old Dec 21, 2010 | 06:37 PM
  #35
f4tal's Avatar
Its 05stepside, and kenny's truck put down like 376hp at like 5k i think.
I know he raced david's H/C 6.0 who put down like right at 400hp.
Kenny pulled david by more than a truck everytime.
Numbers aren't everything, but regardless something doesn't sound right.
Goodluck!
Old Dec 21, 2010 | 08:10 PM
  #36
skyhighsami's Avatar
no title here
Is it not possible that the cam is bleeding off the boost?
Old Dec 21, 2010 | 09:48 PM
  #37
Rick_Vor's Avatar
221/228 581/588 114 LSA isn't ideal but it probably isn't bleeding off all that much boost.
Is 6psi on a 347 enough to get that turbo into its efficiency range?
The 9.2:1 isn't THAT low so it could just be a combination of a not aggressive enough tune and not enough boost. Add fuel, cut the timing and turn up the boost up to 10-12psi then start dailing in the timing and fuel tables.
Old Dec 22, 2010 | 12:04 AM
  #38
black04's Avatar
I calculated the overlap on the cam and its around -3.5 so it shouldn't be bleeding off much boost.
Old Dec 22, 2010 | 08:17 AM
  #39
jts gto's Avatar
I have a nine pound spring on the way. That should hold me over for a little while, I can see how this horsepower problem is going to be troublesome for the old bank account.
On a side note it was totally worth putting bus lengths on a mustang gt last night though!!
Old Dec 22, 2010 | 11:00 AM
  #40
krambo's Avatar
What gear did you dyno in?
