Turbo L9h
Thats great news i was kinda wondering what the limit was on that or if i needed to upgrade to the zr1 maf. I'm glad you jumped in both of you guys are pushing the limits of these trucks and i'd like to find out what to do and not to do. My turbo setup will be different from everybody elses...not over the counter bought but end result should be close to the same. I'v already installed my 85ib injectors so the turbo will be next probably ready to put the knife to it next month. What about flex/fuel pump what are the limits on that? I plan on running e85 with my setup? Another thing is torq management are you guys leaving it on, turning it off?? Any problems so far?
, now the flex fuel pump was pretty much done @ 606rwhp at the time didn't want to keep it there incase of a boost spike which killed my 1st 6.2L, a Boost-a-pump will not work
my builder had to do a stand alone fuel system. In my honest opinion I feel that the stock bottom end 6.2L are good for 600-650rwhp the more i read on other forums more and more have problems north of 650 I did manage to get 709rwhp 688rwtq the 3rd pull on 18lbs but ended hurting it
Ok all good info here...im currently running full torq man at part throttle but im leaving in 8 to 10 degrees at wot when shifting. Im hoping to make high 500's to 600rwhp on E85 just hoping the pump can keep up...if it cant what do you guys suggest doing? Will a drop in pump work or will i need to do a full fuel system overhaul?
edit- just saw you were running E85... you will need a bigger pump for sure. No need for a "full fuel system overhaul".
Max boost on this build will be 8ibs so the maf should be fine for now. The pump im thinking isn't gonna be enough
What do you guys suggest for a drop in pump? Does anyone even make a drop in pump for this truck.
