Turbo injectors
Old May 20, 2009 | 09:21 PM
Default Turbo injectors
Will these injectors work for a 6.0l turbo setup with stock truck intake and fuel rails?
Racetronix
Flow-Matched
Sets
Shorty
60 lb / hr
Injector
Part # INJ-GAS-0002 (S107FM) Part # 107962
Static Flow Rate: 60 lb/hr @ 43.5PSI (300kPa) = 630cc/hr (sold as 65lb/hr by some vendors)
Coil Resistance: 12.5 Ohms / High Impedance / High-Z(No ECM driver modifications required)
Gain: 0.11ms/mg, Offset: 0.055ms, Turn on time: 1.14ms @ 14VDC, Turn off time: 0.85ms @ 600KPa
Wide angle spray pattern
Old May 20, 2009 | 10:33 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
It depends. What turbos? Are you running meth? How much HP are you trying to make?
Old May 21, 2009 | 11:46 AM
Rick_Vor's Avatar
[QUOTE=GENIIIDude;4209991]Will these injectors work for a 6.0l turbo setup with stock truck intake and fuel rails?
Those sound like the same "shortys" I'm running. They should bolt right in without have to add spacers to the stock truck fuel rails. You will still need to pig-tail adapters.
Rick
Old May 22, 2009 | 07:41 PM
gmc6.0's Avatar
how much did you get those injectors for....hey rick how hard is it to pig tail them in...
Old May 22, 2009 | 09:35 PM
Rick_Vor's Avatar
They were around $5 bills with the pig tail from Rick at Synergy Motorsports.
Pigtail install is a breeze. Snip, strip, twist, solder, heat shring tubing. Took about an hour. I had to swing by Synergy the day before the install with the ECU so Rick could program the 60's (took about 2 minutes). Did the install, re-installed the ECU and fired it up.
Rick
Old May 23, 2009 | 08:56 AM
I'm getting my injectors from John at www.fuelinjectorconnection.com, for around 400.00 with pigtails.
Old May 23, 2009 | 10:33 AM
53RUSSELL's Avatar
I got my 60's and plug and play pigtail from him too.
He also has ebay page too.
Old May 24, 2009 | 12:54 PM
phasemaster1's Avatar
Racetronix
Flow-Matched
Sets
Shorty
60 lb / hr
Injector
Not 100% but think those short injectors wont work on our truck intake and fuel rails.
Old May 25, 2009 | 08:06 AM
I was told that these injectors are the LS2 style and require a 1/4" spacer on the stock injector rails to fit. The problem is that the short stock injectors cannot be rebuilt to supply more fuel - I believe the marine 8.1L injectors are the largest at 42 - 44. With my setup I need at least 50's.
Old May 25, 2009 | 09:25 AM
Wilde Racing's Avatar
How do I change this text
Lots and lots of choices, if you have the money a injector driver like the "versafueler" is the way to go. You can run e low z injectors with the stock pcm.
