turbo help
Old Aug 12, 2012 | 09:56 AM
turbo6.2's Avatar
Banned
Default turbo help
Look I'm ready to upgrade my magaum turbo is bout to go to **** I would like to go to a 76mm need some help have a kb kit 3.5 San Diego Forced Induction - Check out our large selection of Turbos would this work or some one direct me to a good turbo got bout 1000 to spend
Old Aug 12, 2012 | 10:42 AM
02'Z71ONDUBZ''s Avatar
Hard to spec a turbo without details of your setup. What is wrong with your magnum turbo?
Old Aug 12, 2012 | 10:49 AM
turbo6.2's Avatar
Banned
Starting to.smoke when I start it up then it goes away I have a built 6.2 rods and pistons hell fire rings bout to install head studs it makes 510 and like 570tq on 10 pounds of boost I'm having value float righ.now so I just got new tritium 700 lift springs so ima go more boost bout 18lbs most likely just need a real good.turbo truck is a 2011 GMC 1500 came whith the 6.2 I blew it up so I.went whith a built set up
Old Aug 12, 2012 | 12:19 PM
lglowe's Avatar
Borg warner s400sx3 76mm- 80mm compressor /87 turbine. Gets my vote
Old Aug 12, 2012 | 12:35 PM
turbo6.2's Avatar
Banned
I onlwy have 1000.to spend not 2 grand but nice turbo.
Old Aug 12, 2012 | 01:23 PM
bud8fan's Avatar
you shure it's the turbo....have not seen any of these magnums go to ****..
Old Aug 12, 2012 | 01:32 PM
turbo6.2's Avatar
Banned
Yeah its the turbo its still good needs new.seals probley ima just upgrade get it off my mind so I need a.good nice turbo that spools nicely and.my price.range but you can't have ur cake and ice cream too
Old Aug 12, 2012 | 02:18 PM
lglowe's Avatar
Those borgs aren't that high. Nonnie selman just put the 75/83 on his truck and he said he only paid 800 ish for his snail. I wouldn't think the next size bigger turbine would be much if any more cash. Gotta look at the right vendors. Reason why I said go for the bigger turbine is because of your cubes and nonnie said his 83mm spools very fast on his 6.0
Old Aug 12, 2012 | 02:41 PM
smokeshow's Avatar
Mod with training wheels
That sx3 is a different series of turbo, not the same as the big rig s400s. They're a little more expensive.
Old Aug 12, 2012 | 02:48 PM
Atomic's Avatar
I have a gauge for that
I have this one...its badass...
It sounds like your oil drain situation is inadequate, so even if you get a new turbo, it will do the same thing.
