turbo help
Old Aug 28, 2009 | 03:33 AM
Most Hated's Avatar
Default turbo help
if i were to change my setup to a 76mm turbo wat would i need i already have the fuel setup with dual pumps 69lb injectors how much would i have to waist money wise ?
Old Aug 28, 2009 | 01:16 PM
SpoolinChevy's Avatar
Well assuming your tranny and rearend are already good, there isn't really anything needed. When I upgraded from the 62 I went ahead and went with 4" exhaust from the dp back. I can't think of anything else besides a tune that should be needed.
Old Aug 28, 2009 | 06:31 PM
Most Hated's Avatar
how many lbs of boost can a 76mm put out ? and on turbos how do u control the boost ? like for example on the radix u change a pulley and on the turbo ?
Old Aug 28, 2009 | 07:04 PM
nlawson6.0's Avatar
change boost with a diff springs in the wastegate. and what 76mm turbo are u going with?
-Nate
Old Aug 29, 2009 | 12:43 AM
Most Hated's Avatar
master??? something i forgot the name , but im going to buy first the turbo then the intercooler etc........ , can any one give me a list of parts of what im gonna need if i buy it separate
Old Aug 29, 2009 | 01:04 AM
stock48's Avatar
9 Second Truck Club
The T76 is good to about 14~16PSI on a 6.0L depending on heads and cam. If you have good heads, and the right cam boost will drop and HP will go up. 12~14psi on a 6.0L with a decent cam, and converter should go easy 10's in your truck with traction.
Kyle @KB racing sells the Master turbos, hot pipes, and everything else you will need seperate, or in a kit.
https://www.performancetrucks.net/fo...ront+mount+kit
kha4079
Oct 29, 2018 04:38 PM
lxcoupe
Sep 6, 2017 08:24 AM
jtphelps289
Sep 11, 2015 06:37 PM
slowswb
Sep 5, 2015 02:27 PM
06murder
Sep 4, 2015 03:54 PM
