Turbo headers vs manifolds?
Originally Posted by Stampede4ever
Is there a big difference betweent the two, I'm not looking for all out power. I will be building my own headers, if needed.
Thanks.
Thanks.
We build one log manifold and reuse the drivers side, makes plenty of power.
Rick
This completely changes depending on the turbo and boost level. For most "streetable" boost levels, the stockers are actually better than headers (retains the heat better) IMO, but as the guy who set **** on fire during a single dyno pass at 14psi, sometimes heat ain't all that
They do flow better / as well as any shorty header on the market, but don't flow as well as a good set of LTs or Middies.
If you are going to run 10-12psi max on a stockish motor and can figure out how to keep the stockers, do it. If you're going bigger / higher, can can make a good flowing set of headers, do it (else look for a fab shop imo).
They do flow better / as well as any shorty header on the market, but don't flow as well as a good set of LTs or Middies.If you are going to run 10-12psi max on a stockish motor and can figure out how to keep the stockers, do it. If you're going bigger / higher, can can make a good flowing set of headers, do it (else look for a fab shop imo).
Stainless Works
Apr 10, 2016 04:34 PM
Suburban2500
Jul 13, 2015 09:57 AM
