turbo guys inside
#26
GFYS and STFU
Well, I think it depends on how much boost you plan to run and how quiet you want it to be when out of boost. Personally I like it as quite as possible when just driving around which is why I have a stock 2500HD muffler. And I can boost up to about 6lbs before I have to open my cut-outs for anything over that.
Here's with a cut-out open.
http://www.youtube.com/watch?v=Qzp3-pUavkU
#27
hahahaa..i love it i will def get a cut out. what size is yours spoolin? how much comp. is your motor? i have talked to everyone and they say im ok. but i want to run 13 psi or so on 10.2:1....
spoolin also what kind of blowoff do you run? love the sound it makes.
im running a tial 50mm, and a 44 gate.
#28
If you were referring to me, I have the TurboSmart Race Port (50mm) bov. I had a 38mm before, but i upgraded to help with compressor surge.
Not trying to hijack your thread, but do you see any difference in power with the cutout open Spoolin?
#29
GFYS and STFU
As far as the blowoff it's a Tial(forgot the size) but basically the stronger the spring the more chirping it will do, the weaker the spring the more it will sound like the Fast and Furious.
Because of the way I set my truck up there is a big difference yes. And in most turbo systems you'll see a couple psi difference with a cut-out depending on what kind of exhaust you have and where you place the cut-out. Because I wanted a real quiet truck when in traffic and around cops I stuck with a stock muffler which doesn't allow too much pressure differential accross the turbine. But with the cut-out 6" from the turbo outlet and before the cats and muffler I go from a max of 7psi with it closed to 18psi+ with it open. And obviously the power is very different...as you can imagine, it's about 400hp/tq difference but my set-up is extreme. My truck doesn't really wake up until I hit about 10lbs of boost anyways... again, cam choice is critical on low compression engines.
