-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   Turbo gearing 4.10 --> 3.42 (https://www.performancetrucks.net/forums/forced-induction-159/turbo-gearing-4-10-3-42-a-525003/)
GMCtrk Dec 25, 2013 03:58 PM
I have a set of used OEM 3.42s laying out in the garage that I got basically for free. I've currently got 4.10s and my tires are a hair over 28" so it's a pretty short overall ratio. People toss around the generalized statement that turbos love tall gears, but anyone with any actual experience? Only person I could find searching was black 4.8.
BlackGMC Dec 25, 2013 04:23 PM
I am in the same boat but with my new boost controller i can make 9lbs at 3200 easily.
sleeperlqx Dec 25, 2013 05:16 PM
I would like a answer to this as well. But from what Ive gathered tall is better as it loads the turbo quicker so it gets into boost faster. Here is the thing. Im not sure to keep my 3.73s in my Tahoe, or go with some 3.23s to LOAD a big turbo like a s480 up with a T6 flange. That should keep it in boost often, and also pull crazy up top as its always loaded better. But Im going to try it with the 3.73s at 1st. I have a 4 speed 80e.
kelsey_canard Dec 25, 2013 05:21 PM
Same boat here. Rocking the 4.10s. Like to hear peoples responses.
LS1TRUCKGUY Dec 25, 2013 05:56 PM
I have 3.73 in mine with a 30.5" tall tire and an 80e and love it. I cant compare it to another gear ratio though. I can say with the tall 1st gear of the 80e, I wouldn't want anything taller than the 3.73s. I have a small turbo, but I'm at full boost under 3000rpm
Atomic Dec 25, 2013 06:54 PM
Longer gears load the converter more. You need to match gears to your converter.
smokeshow Dec 25, 2013 07:24 PM
Ahhh, the load argument...it burns. Too much time wasted fighting that nonsense lol.
ZO6Ted Dec 25, 2013 07:38 PM
My only experience was when I was at only 5.5lbs with a very conservative tune with the 67 mm rear mount. My first time at the track with a 4l60 and3.42s and 26-2800 10.5" converter, 20"x32" tire. A VERY disappointing 9.54 in the 1/8th. What a pig!!! 4.10s front and rear, same weather conditions, 8.90 few days later no other changes whatsoever. You asked, that was my experience.
tim wellington Dec 25, 2013 08:28 PM
4l80e with 373 7'90 1/8 changed to 410 7'64 1/8
trxmxzx Dec 25, 2013 09:31 PM
I'm in the same situation- still have some 3.42 and currently running 3.73 - 30.8" tire in a 2wd setup- it was awesome N/A but now boosted I can't hook well and it runs out of gear quick IMO. I'm thinking it would help the traction issue some and give me more up top.
My past experience was n/a and probably doesn't compair the same- buddy ran 3.73 In his truck and I had 3.42 he would put a truck on me easy at a launch, but at about 60-70 mph i usually came back hard and caught up faster after those speeds. I put my 3.73 in and we where damn near head to head whom ever got the launch better.
