Turbo for a gapped 5.3
Old Aug 13, 2022 | 09:48 PM
Jonlxa415's Avatar
Default Turbo for a gapped 5.3
Help me find a good size for my truck I have a gen3 5.3 and a 4l80 with circle d 3k-3.2k stall still the stock 3.73 gears. It’s a 2008 4wd crew cab I am trying to reach around 700-800 hp the engine build is below. I plan on getting 120lbs injectors and twin 340 pumps in the tank. I just got a Huron t4 kit without the turbo and wastegate so if y’all and any advice I would love to hear about it.
I want this to be a fun strictly street truck to blast around town. I hardly tow but I would like to haul *** reliably. -PAC 1219 valve springs with new valve seals
-Elgin 1840P cam 228/230 112 Lsa
- King main and rod bearings standard size
-Ls9 headgaskets with speed master head studs
-Rings gapped to .026 top and .028 bottom rings for boost/nitrous
-New melling standard pressure oil pump with new pickup tune o ring
-new cam retention plate
-New Elgin LS7 lifters
And new front/rear cover gaskets and crank seals.
need help finding
turbo brand and size
gear size
wastegate brand and size
Old Aug 14, 2022 | 08:21 AM
RDF1's Avatar
DuNnO
5 Year Member
The vsracing billet 7875 can make 815hp to the tire on a mustang dyno. It spools pretty good on 5.3s and 6.0s.
Old Aug 14, 2022 | 11:44 AM
Feed's Avatar
What's your budget? Vs racing 78/75 should do it. Our look into something similar from Forced performance.
Old Aug 14, 2022 | 12:21 PM
Jonlxa415's Avatar
Since I’m at the end I was gonna get a bw or a vsr I don’t really have a budget just want reliable if I can squeeze out enough to get around 800 I would be happy. What about the wastegate? I was looking at eTurbo2 controller and some wastegate maybe a 44size
Old Aug 14, 2022 | 01:08 PM
Feed's Avatar
VS has wastegates. 44mm will do. 3.73 gears are good as long as you don't have oversize tires.
Old Aug 14, 2022 | 01:57 PM
Jonlxa415's Avatar
no oversized been there done that I want a family sleeper only way to tell is hear that turbo woosh by you.
slowlowtaco
Mar 2, 2023 03:35 PM
kush killer
Oct 4, 2012 08:55 AM
TheRepairMan
Oct 24, 2011 07:25 AM
Stampede4ever
Aug 9, 2008 04:16 PM
