Turbo Daily Build Thread
Old Mar 28, 2016 | 12:00 PM
walledition's Avatar
Nice project, really like the clean gauges, can there wideband be used to log with hptuners? Is the boost gauge electrical or machanical?
Old Mar 28, 2016 | 12:55 PM
mdwatts11's Avatar
Originally Posted by TrickTurbo
Don't extend maf wires.
Just unloom them. There's plenty there just takes a little time.
Yea, I didn't mean to say that I extended them. I just pulled them from the loom. There should be plenty! I just coiled it up and ziptied it near the firewall there. Still need some more split loom to protect it once I get the maf moved down in front of the engine.
I haven't tried logging with it yet. I do have it setup to though. The controller is mounted in the engine bay with the 0-5v wires coming into the cabin and up to the gauge and I have additional wires soldered into them and run under the dash to the center of the truck so they can be plugged in to the tuner.
As a matter of fact I don't have the wideband hooked up yet. The sensor is disconnected until I get the turbo installed. It was pointless to weld in a bung on the factory exhaust since I am about to take it off.
Old Mar 28, 2016 | 12:56 PM
AkSSS's Avatar
That's different on the Vacuum block. I like that.
Old Mar 28, 2016 | 02:35 PM
Choda's Avatar
leave the ac line alone until you dry fit the turbo and downpipe. Nice job.
Are you going to run the water lines how I ran mine or all the way over to the fender then up to the heater core?
Old Mar 28, 2016 | 02:37 PM
mdwatts11's Avatar
Yea, its a cheap-o off Amazon. It was $20 or so. It doesn't leak and does a what I need. I was going to mount it to the firewall but there weren't any flat surfaces for me to mount it where I wanted. It just happened to be the perfect spacing between the bolts to mount it on the coils with some longer bolts and spacers. It turned out pretty decent I think.
Old Mar 28, 2016 | 02:38 PM
mdwatts11's Avatar
When I did the cam swap last year, I rerouted them behind the battery and then up along the fender and under the coolant reservoir.
Old Mar 28, 2016 | 07:51 PM
Frizzle53's Avatar
Nice build, post lots of pics. I'll be doing my turbo build at the end of next month but with ricks stage 2 kit.
Old Mar 28, 2016 | 09:49 PM
mdwatts11's Avatar
Can't really do much tonight. Had to work later and besides I can't do much else until I get the injectors.
So, I spent my time gapping spark plugs.
TR6 at .030"
Old Mar 28, 2016 | 10:47 PM
mdwatts11's Avatar
Should I just get ID1000s? Any difference in the driveability between those and the 850s? They are the same price so I feel like I might as well just get those.
Old Mar 28, 2016 | 11:00 PM
echoman's Avatar
Awesome! Kyle at KB just finished my kit today with the S369 and is shipping it out tomorrow. Can't wait to see how yours turns out!
