Turbo CC 5.3
Old Jul 12, 2019 | 08:28 PM
ZO6Ted's Avatar
I'm sure you thought of this but are you lowering your rear tire air pressure?
Old Jul 12, 2019 | 08:52 PM
Superman956's Avatar
Yes I had lowered to 20PSI I was at 40
Old Jul 12, 2019 | 11:01 PM
ZO6Ted's Avatar
Since you're spinning then a sticky tire for starters. If it still doesn't plant or hops work on the rest. No way you can make a hard tire hook. Not sure what you've got and how old they are but that's where I'd start. Then you'll know what else depending on wrap or hop or...
Old Jul 13, 2019 | 05:19 PM
I just don’t know which ones. Drag Radials (to drive daily) or Slicks. Which is why I made the thread to see what’s up
Old Jul 14, 2019 | 08:19 AM
smokinlmm's Avatar
Too much gear, need to come down to get traction in dig. You've got gearing for 1/8 mile not 1/4 id gear down so you can boost it off the line or have your converter loosened up or have coupling changed up...
Old Jul 14, 2019 | 09:08 AM
1redta's Avatar
I agree with the overall ratio being to high for the current setup. Sticky tires then go back to 3.73 if that doesn’t help
Old Jul 14, 2019 | 11:49 AM
Sucks to read this piece because 2 weeks ago I just fixed it again and my tuner said to put 4.30s since I run larger than normal tires
as far as the converter how can I loosen it up? Because I already have a lot of vibration that I need to work on
Old Jul 14, 2019 | 09:45 PM
randeez's Avatar
Most drag radials only go up to 29", et streets I think go up to 31" but you need to go down to 15" wheel
Not sure what's available with slicks
You're going to effectively be even more over geared
Old Jul 15, 2019 | 06:44 PM
ZO6Ted's Avatar
I'm not convinced he's over geared yet at least imho based on my past results. What's your tire diameter currently?
Old Jul 15, 2019 | 07:54 PM
Lol thanks man
it’s 32” = 305/50/20(20x12)
was thinking of getting a 29.5” drag radial R MT
