Turbo build tune questions
Old Oct 14, 2015 | 08:53 PM
  #31
Silveraydo's Avatar
Sounds like I'm going to use them! I was looking at MAP sensors and that part number is about 100 bucks and thereturn is another one thats like $50-$60 delco 2134658. I believe it is a 3.3 bar from a duramax. It fits directly in place of factory MAP.
Old Oct 14, 2015 | 08:57 PM
  #32
GMCtrk's Avatar
The duramax sensor isn't a good option.
Take it from me and get the 2.5 bar from Gagetized on here. It's a direct factory replacement and good to 22 psi at sea level, which is way more than the part list in your post will support.
Old Oct 14, 2015 | 09:15 PM
  #33
Silveraydo's Avatar
thanks for the input. it only took about 2-3 google searches to convince me not to use the 3.3 i just liked the factory replacement. ill get that one you mentioned then.
Old Oct 14, 2015 | 10:14 PM
  #34
Silveraydo's Avatar
im ordering the MAP from gadgetized. and orderd an IAT from DIYautotune with a pigtail. from what i have found its the black and tan wires that i need to cut from factory MAF connector and extend to IAT a few inches from the throttle body? and polarity doesnt matter. once i have both of these installed i no longer need ANY of my factory O2 sensors, i will have my wideband in. Does my wideband need to connect to anything else? i feel like it does considering its got several connections/ harnesses on the back of it and the only thing i have is a VGA looking chord coming from the "in" connection out of my dash and the actual wideband sensor itself. after all of this i will be set up for a sped density tune which can be tuned to my stock PCM? i alos dont understand open loop/ closed loop but i feel like ive read tha has something to do with my wideband?
Old Oct 14, 2015 | 10:18 PM
  #35
GMCtrk's Avatar
Open loop is no oxygen sensor feedback to PCM. Closed loop is factory calibration with oxygen sensor feedback for fuel trims.
There's another condition you can run called semi-open loop as well.
Old Oct 14, 2015 | 10:39 PM
  #36
Silveraydo's Avatar
hmm ok. im guessing there are pros and cons to each? any particular one thats best for a daily driver?
Old Oct 14, 2015 | 10:40 PM
  #37
GMCtrk's Avatar
closed loop
Old Oct 14, 2015 | 10:58 PM
  #38
Silveraydo's Avatar
ok done. thanks
  #39
Silveraydo's Avatar
in that case my wideband is just for me then correct?
Old Oct 15, 2015 | 03:41 AM
  #40
Show-n-go5.3's Avatar
Originally Posted by Silveraydo
Awesome man i appreciate it. thanks for the part number!
FYI When u mount the Map sensor, mount it as close to the intake plenum as possible (on it is best).
