Turbo Bogging Issues??
Old Apr 24, 2009 | 02:36 PM
TWISTED SilverBullet's Avatar
Exclamation Turbo Bogging Issues??
Hey guys. I got a problem with my truck at highway speeds of about 55 to 85mph. If i get on it in drive then my trucks begins to bog after a few secs. I though it was some kind of tuning issue. I did notice that when my meth spray light comes on at about 5lbs of boost then the truck does the bogging in and out of power thing. When I run the truck in third gear tho the trucks seems to pull fine. I knoe they tune my truck on 3rd gear on the Dyno, maybe they should dyno tune it in drive? Any takers? Thanks
Old Apr 24, 2009 | 02:43 PM
BlackGMC's Avatar
Resident Retard
What does your AFR go to when this happens?
Old Apr 24, 2009 | 02:58 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
^ yeah, sounds like it goes way rich when the meth hits, converter locked. In third with coverter unlocked your rpms will be a lot higher.
Old Apr 24, 2009 | 08:45 PM
silveradol33's Avatar
Im with Trev on this one, I think when the meth is hitting the afr is going real fat and making it bog, try taking out some fuel when the meth hits.
Old Apr 24, 2009 | 09:06 PM
bostinchevy13's Avatar
do u have a smaller nozzel for the meth kit????
Old Apr 26, 2009 | 06:15 PM
Well i posted this problem somewhere else in this forum at the same time and someone said my tq converter is probably loose which causes my trouble codes to go off because i get thrown into safe mode. I did notice that my "shift solenoid b stuck on" code goes off frequently causing me to be stuck in third unless i shift manually. It goes away after I turn off the ignition for a few seconds. Also I throw bank 1 and bank 2 lean codes at the same time, which kinda throws the running rich theory out, right? The guy said continued abuse could burn up bands two and three. Does this sound about right. Also I dont have any other nozzles for the meth. Thanks guys
Old Apr 27, 2009 | 04:51 PM
Last Call's Avatar
TOTM: January 2007
Hey what up Shareef! Its Jay. I have my tuning software, we can log your truck and figure it out. Do you have a wideband?
Old Apr 27, 2009 | 06:18 PM
Spoolin's Avatar
GFYS and STFU
Jason to the rescue!
Old Apr 27, 2009 | 07:59 PM
Dude you are the bomb. Glad to have ya as a friend. You know my setup and seem my truck in action. Dont have a wideband, but I can get one easily. Im taking my truck to Schucks tomorrow anyway so he can take a look. They're taking a look since its under warranty anywayz. What do you want me to do.
Old Apr 27, 2009 | 08:36 PM
Last Call's Avatar
TOTM: January 2007
I would recommend a wideband, I have an innovate xd16. I am in Virginia now for work, but when I get back in about a week, we can take a look at it. We can log the trans to see if it is slipping.
I think it is the methanol dumping in when you hit a few psi of boost. If you get a wideband, it will be easy to see. If it is the methanol, you can lower the ramp rate of the controller and that may be fix some of the issue.
We can talk more when I get back.
