turbo or blower?
Old Jan 11, 2017 | 11:50 AM
stroker87's Avatar
from a cost stand point i think once its all said and done turbo "might" be a little cheaper but TVSxxxx is simpler to install other then that i'm sill lost lol
every time i ask some one i get 10 reasons no to go turbo then ask some one else i get 10 reasons not to go blower
Old Jan 11, 2017 | 11:57 AM
Atomic's Avatar
I have a gauge for that
Could always build a NA big inch 8000rpm screamer lol would get terrible gas mileage but be cool
Old Jan 11, 2017 | 12:05 PM
stroker87's Avatar
took me a while to get use to 6800rpm with my z06 lol my brain kept telling me shift shift at 6k, @ 8k would fry to many brain cells LoL!
Old Jan 11, 2017 | 01:57 PM
ZO6Ted's Avatar
Also what rpm do you spend most of your driving? The turbo has a hell of a top end charge but compared to a PD blower is soggy on the low end. Still can be good performance though as can a PC. I had very little trouble with turbo but it did happen on occasion. Just requires checking **** more often. My Whipple I just turn the key and drive. The low end makes it feel much more powerful than it is and shooting through traffic is instant. Its like whatever my will is, it happens and right now. My turbo with the converter it required was lazy at every stoplight unless I got into the throttle pretty good then it was hang on. Whipple is stock converter although I do have a 6l80. I just prefer driving in the 1500-3k range on a daily basis with still great just not as great performance as a snail setup. 600 can be had with any of these but 700 is a lot tougher with a PD for daily use.
Old Jan 11, 2017 | 02:22 PM
stroker87's Avatar
85% of the time like you mostly in the idle to 3k rpm range daily driving, i'm not always beating on my cars but if something pulls on the side of me that actually has some power i'm ready (not a mini van or kia)
my 01 zo6 right now makes 475/415 wheel NA and has enough power to keep in front of 90% of whats on the road for the other 10% i have nitrous 600/599 wheel have not tracked it with the nitrous but NA best 11.21 @ 122mph 1.50 60ft, on spray i pull from my cousins stock c7 zo6 my other cousin has a modded 13 gt500 740+ wheel and we are door to door
with that said i'd like this truck to have the same performance or close to it i'd love to have a 10.50 1/4 mile truck but high 10's low 11's i'd still be happy (at least i'm telling myself that) but i want it to be reliable, i'm not one to let something sit in the garage my car is my daily driver summer time and was built with that in mind when picking a cam, clutch and exhaust
i don't mind extra maintenance but i dont want to be fixing the same thing 3 times a month, so you guys with turbo's how often are you doing maintenance and whats the biggest problems your having?
i really want a turbo but just worried about it being a headache
Old Jan 11, 2017 | 03:00 PM
Atomic's Avatar
If I DD a turbo truck I would make sure to install a good oil cooler, and change the oil every 3000 miles or 2 months, this is the biggest thing. Obviously you have to take steps to deal with the heat that will be there in terms of routing stuff and heat shielding, but this is usually a 1 time deal.
At the latest inspect seals, gaskets, hot pipe welded joints, and connection points every couple months for leaks or burns. The heat cycling on turbo setups is quite a bit more punishing for the the hotside especially.
Old Jan 11, 2017 | 04:48 PM
stroker87's Avatar
i usually do oil changes every 2600 to 3000 miles or before i go to the strip so thats no big deal, inspecting under the hood is not a big deal either
i guess maybe i'm asking the question wrong....
is there enough room under the hood for a turbo to be installed far enough away from every thing not to burn stuff up (once every thing is move or rerouted) i'm keeping a/c
Old Jan 11, 2017 | 05:00 PM
A4edwin's Avatar
do you still have the same issue if it's a water cooled turbo?
Old Jan 11, 2017 | 05:16 PM
Atomic's Avatar
Yea of course, if you can deal with the more maintenance aspect then go ahead and get a baby turbo that spools fast and pretty much acts like a blower. Wont be "instant" boost but half a second is pretty much instant. It wont have the top end, but it will drive good and still make the turbo noises.
I think the watercooled turbos are pretty gimmicky how they are used. The Comp ones anyway have that "feature" because their bearing design sucks and they would fry without them, and when you would really benefit is when you turn the engine off to cool it down faster to prevent coaking on the bearings but not many people use an electric pump with it so that doesnt work either. And comp turbos suck.
Old Jan 11, 2017 | 05:19 PM
kbracing96's Avatar
You're gonna have a hard time getting that kind of performance out of blower alone without going all out with at least a 2300, 8 rib drive ect. So your going to have a chuck of change in it. Or spray it too.
Blowers are a lot of fun, I probably like them more for a 5-600hp daily then a turbo, but for the kind of number you're wanting your really gonna need a turbo.
Coming from a guy who dailys a turbo, you're way overthinking the maintenance and melting stuff issues. I don't have any of those kind of problems.
