Turbo 6.2
Old Aug 16, 2012 | 03:38 PM
  #21
nonnieselman's Avatar
We gonna learn him something before long!
  #22
9 Second Club
Originally Posted by lglowe
Again the compressor is not your big issue. I think if you upgrade to that 76 you will have minimal gains at the boost your at now. You need to re think the hotside of the turbo.
Suggestion on a cheap turbo to test this theory? I know almost nothing about turbo sizing.
Old Aug 16, 2012 | 03:40 PM
  #23
Call trick and see what options he has for you since you have his kit, he should be able to suggest a turbo that will bolt in.
Old Aug 16, 2012 | 03:44 PM
  #24
9 Second Club
He's the one who gave me the option to go 76mm.
He also gave me the option to reconfigure the manifold and go even bigger. I just want to make the most cost effective decision at this point.
Old Aug 16, 2012 | 03:55 PM
  #25
I completely understand,
i have the Borg Warner S475 with a 83mm 1.0AR and its perfect for what i wanted it for.. Towing. i can pull a hill and not get in boost, but if i want boost its only a lil more throttle away.
Old Aug 16, 2012 | 04:13 PM
  #26
lglowe's Avatar
I think all you'll have to change to run one of those Borg warners is change the first couple inches of the down pipe since its a big frame turbo and has a 4" v band...
Old Aug 16, 2012 | 04:33 PM
  #27
9 Second Club
So basically all I would have to do would be cut the V-band off, and flare it out to 4" then put a new V-band on?
Old Aug 16, 2012 | 04:37 PM
  #28
lglowe's Avatar
Dunno exactly. Trick or kb would know for sure how to mod it
Old Aug 16, 2012 | 04:47 PM
  #29
its a 5" vband on the outlet of a BW..
and i believe kyle said the there is a slight diff in the exhaust housings the way they bolt on?
  #30
heck the comp outlet has a 3.5" vband
