Turbo 5.3L @7# = 311hp 360 tq
#27
Slowest turbo build ever!
Get a bigger fuel pump in there ASAP. My stock fuel pump is loosing pressure from 4k+ and im not even FI. Had to have Justin(BBP) adjust my tune untill I can get my new walbro in. Im about 99.9% sure thats your problem. After you get a new pump in there get it retuned then see if you have anymore problems .
#29
Mod with training wheels
I saw that he mentioned bumping up boost. What makes me curious is the second pull at 12psi is a lot smoother than the one on 7... The second pull actually looks OK, except that it is a whole lot lower than it should be. I'd check out that dyno, especially if other cars weren't putting down the expected numbers.
