Turbo
Old Feb 24, 2008 | 12:20 PM
ONLYA4.8L's Avatar
I see... I want to get as much outta my stock displacement 6l.. wanna see if 700hp is possible with it..
Old Feb 24, 2008 | 12:24 PM
BlackGMC's Avatar
Resident Retard
Originally Posted by ONLYA4.8L
Got an 01 scsb silvy with 6.0l swap.. 226/226 .580/.580 112lsa with 3200 stall and 4:10s. Wanna know a good turbo system to go with to get more bang for my buck. Was lookin into STS but wondered about opinions on what else is out there.
I might be wrong but I think your cam (mainly LSA) and your converter are a little bit tooo big to run a turbo.... You might want to pick a different cam and convertor
Old Feb 24, 2008 | 12:51 PM
ONLYA4.8L's Avatar
****... Well Need cam and converter help... And wanna know what size turbo.. Gonna use 72lbshr injectors but need a good fuel pump..
Old Feb 24, 2008 | 12:53 PM
TrickTurbo's Avatar
Truck Sponsor
I like those set ups... But after lookin at the design. I was thinkin.. 2 may be better then 1..
thnks,
1 will fit most applications and give the HP they want. Now is you want Twins, we have been looking for a customer to build the low mount twins for. Just need a small installment to get rolling.
Old Feb 24, 2008 | 12:59 PM
ZO6Ted's Avatar
Do a lot of research before you pull the trigger. There are so many great options available now, I don't know if there is a bad choice. Take a look at the fastest trucks list to get an idea for what works or the dyno list if numbers are more important. Good luck and have fun with the journey...it never ends.
Old Feb 24, 2008 | 01:02 PM
ONLYA4.8L's Avatar
interesting......
Old Feb 24, 2008 | 05:04 PM
Wilde Racing's Avatar
How do I change this text
Originally Posted by 8ALTNG
trick or livernois(sp). Those are the two good ones that I have seen. Or you can have one built
Only run an STS if you want to be; different, tow, or go faster........
Do some searching and don't for get about the trans!!!!!
Old Feb 24, 2008 | 06:03 PM
8ALTNG's Avatar
How could I have forgot about the STS. great kit for what it is.
Old Feb 24, 2008 | 06:07 PM
wastedrubber's Avatar
in all fairness, he mentioned a little knowledge of the STS kit in the initial post, he was asking what other kits were out there
Old Feb 24, 2008 | 06:12 PM
quicksilverado's Avatar
STS will take you a long way. Find someone with 500-600 rwhp and go for a ride. Most people see big #s and think it is for them. 500 is more than a lot of people realize. Your stall should be fine. 60 lb injectors will get you 750 rwhp with a couple off fuel pumps. Like Wilde said get ready to do a tranny swap.
