Turbo 370ci build
I'm finally getting around to doing a new engine for my truck so far here are pictures and specifications of the engine. All of the parts are off the shelf nothing was custom made.
Block- LY6 Bored to 4.030
Crankshaft- Stock 2000 ls1 crank
Connecting rods- Lunati 6.125" Pro I-beam
Pistons- SRP Professional Series 4.030 bore -5 dome volume
Cam-Thunder racing TR224 112 LSA 224/224 .567 /.567
Cylinder Heads- Patriot Performance Predator heads (205cc Intake Runner, 63cc Combustion chamber, Patriot Gold Valve Springs with Titanium Retainers)
Lifters- GMPP LS7
Pushrods- Patriot Performance 7.600"
Oil Pump- Texas Speed LS6
Headgaskets- cometic .051" Thickness and 4.030" bore
Turbo Kit- Trick Performance Stage 4 with JGS500 50mm Wastegate upgrade and hot parts Ceramic coated.
Turbo- Magnum 76mm Journal bearing
Lifters- GMPP LS7
Yea they are 7.600 patriot said most people use the 7.650. The compression worries me a little it comes out to 10.72:1 but I'm going to try it see if it works out good. I have ran 10.2:1 on pump gas on 14lbs on a car and never had any problems. The cam is not the perfect one for the engine but I have it so I am going to use it.
