truck surging
Old Aug 25, 2010 | 07:26 PM
  #21
bad cutt's Avatar
ok i was watching o 2 sensors when i get on it it goes to 900 mv. tcc goes to low duty cycle when i am at wot. it is at 96 percent most of the time though. im not sure i understand how duty cycle works. as far as tcc slip goes it actually goes negative when i get on it.
Old Aug 25, 2010 | 07:54 PM
  #22
1BADAZZSS's Avatar
Are you speed density or MAF? Have you tried it without the meth? I had problems soaking the MAF with meth in boost even though it nozzle was downstream. Problem fixed when I went SD
Old Aug 25, 2010 | 08:29 PM
  #23
bad cutt's Avatar
I am SD. It is the same with and without the meth.
Old Aug 25, 2010 | 10:17 PM
  #24
rickjamesCC's Avatar
Dude you are too rich had the same problem I believe the MV need to be about 930 or so ck your AFR that's important!
Old Aug 25, 2010 | 10:34 PM
  #25
AKlowriderZ71's Avatar
11 Second Hall Moniter
When I read this, I thought it might be the transmission or TCC slipping. If you're locking the converter on WOT, you may be getting ready to lose the 3-4 clutches and/or the converter clutch. Definately get the wideband on there and check it also, but if that's good to go, your transmission probably isn't.
Old Aug 26, 2010 | 10:56 AM
  #26
bad cutt's Avatar
I'm not too worried about the trans it is a performabuilt and has less than 2 k on it. But I have broken 2 performabuilt already so I guess its possible.tu
Old Aug 26, 2010 | 08:33 PM
  #27
bad cutt's Avatar
any other ideas?
Old Aug 27, 2010 | 06:01 AM
  #28
TURBHOE's Avatar
is it a triple disk converter? have you logged tcc slip?
Old Aug 27, 2010 | 10:58 PM
  #29
bad cutt's Avatar
New wastegate fixed it. Thanks for the helpu
Old Aug 28, 2010 | 01:24 AM
  #30
Good deal! Too many times guys don't post up the fix.
