truck sputters under boost..fuel problem?
Old Feb 10, 2010 | 10:29 AM
Wilde Racing's Avatar
How do I change this text
My missfire under boost was a bad coil pack. But you need a wideband and a why to log which sounds like what you are doing. I would not "go into boost" until you have some way to watch what is going on....
Old Feb 10, 2010 | 11:01 AM
LsxCody's Avatar
^^^yeah id get a wideband soon
Old Feb 10, 2010 | 08:30 PM
Tall_n_turboed's Avatar
hey thanks guys im gonna start checking things, i havent been driving it since but when i find out ill post the soultion to let yall know
Old Feb 11, 2010 | 09:10 PM
ok so i started testing for problems and the first thing i did is what farm ruck said and take a dirve withe the fuel pressure gage and found is that i had good fuel pressure at idle but as i went up in load it started dropping and when boost came in it dropped down to as low as 20 psi and when i shut the truck off it blead straight to 0 psi, so i changed the pressure regulator but turns out it was the 12" line that goes from the fuel pump the the top of the pump, it had a split down the side
also i bought the wideband and also got a perminate fuel pressure gage
and bought the ngk tr6 plugs, so ill take it out tomarrow and see how much better it runs..
thanks for all the help.
ferrellrooster
Mar 6, 2025 03:22 PM
wrb002
Aug 31, 2015 12:00 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
Suburban2500
Jul 13, 2015 09:57 AM
