trick turbo kit...(turbo upgrade)
I currently have the stage 3 kit on my 2012 GMC with the PT7475 with T4 flange. I'm wanting to upgrade my turbo what would be a good turbo to upgrade to with minimal if any changes? Looking to get around 800 rwhp with my upcoming 6.0 swap.
Also somewhere down the road i plan on buying a 06 regular cab to put the trick kit i currently have on my 2012 in the 06. Will this work? or what will be needed to make it work? Thanks |
I believe byrdman went w a bw unit when he went for big power.
Crank up that boost, Shoot the meth!
76/75cea. Bolts right up.
But 800 hp gonna need to spin it up. 20-23psi. Where you at now in power and boost? The Borg units are great. Require new down pipe and I would go ahead and do 46mm waste gate. |
Originally Posted by TrickPerformanceProducts
(Post 5302538)
But 800 hp gonna need to spin it up. 20-23psi. Where you at now in power and boost? The Borg units are great. Require new down pipe and I would go ahead and do 46mm waste gate. would a 76/75 be adequate on on 6.0? any way i could get a 88mm to work? |
(Post 5302538)
Where do you dyno in Houston?
Originally Posted by GMCtrk
(Post 5302671)
Originally Posted by Jake75
(Post 5302675)
D3 performance
Also, I've seen a poster on ls1tech go to the PT82 I think it is....should be a bolt on for T4 |
S480 or s484 with a 96m turbine. Get Rick to do the downpipe and you want to disappointed.
