Towing w/ a radix
Old Oct 17, 2007 | 08:59 AM
  #41
Wilde Racing's Avatar
How do I change this text
Originally Posted by BlownChevy
Maybe I should drive my truck up to Reno some day and we can see who is slower
I was just messing with ya
Old Oct 17, 2007 | 10:51 AM
  #42
DrX's Avatar
DrX
Originally Posted by Wilde Racing
I'm not sure if this will help you, but here is a HUGE tuning secret of mine for 2 bar tow tunes..
Run in P.E mode all the time except decel. This is easy to do with HPTuner; you just command p.e fuel at anything over 1% throttle. (Not 0%, this keep DFCO working), then zero out your p.e fueling, and add fuel solely from you b.e fueling. You will be basically running open loop, but B.E fueling will add at 100 kpa regardles. That way 2 psi of boost gets 13.5 a/f ratio (or what ever you want) at 2,000 rpm or 6,000 rpm. This makes tuning for fuel mileage and EGT much much easier.......
That's what I was referring to(B.E.) with extending the commanded fuel table in boost. There is no B.E. in EFILive. I see that HPT also has the Main VE table extended instead of having 2 separate tables.
Old Oct 17, 2007 | 11:43 AM
  #43
BlownChevy's Avatar
blownerator
25 Year Member
I know
Old Oct 17, 2007 | 01:06 PM
  #44
Spoolin's Avatar
GFYS and STFU
I know
I'm here Huckleberry!
Old Oct 17, 2007 | 01:09 PM
  #45
BlownChevy's Avatar
blownerator
25 Year Member
get your pile running first ......and thats "I'm YOUR Huckleberry"
Old Oct 17, 2007 | 01:12 PM
  #46
Spoolin's Avatar
GFYS and STFU
Whatever *** hat!
Old Oct 17, 2007 | 01:13 PM
  #47
BlownChevy's Avatar
blownerator
25 Year Member
Whatever *** hat!
:yawn:
Old Oct 17, 2007 | 07:59 PM
  #48
That sucks, because with a little rich a/f ratio at very low boost helps out a ton with torque...
Old Oct 17, 2007 | 08:07 PM
  #49
moregrip's Avatar
what a rush!
so when do I get a ride in that STS truck of yours?
Old Oct 17, 2007 | 08:15 PM
  #50
As soon as I get an engine that all 8 cylinders contribute equally....
As soon as I get a ride in a MP122 powered pick-up.......
