Torque converter selection
I'm in the process of building a 2010 Silverado RCSB 4x4 turbo truck. It's a low mile 5.3l with the 6l80 trans. Right now I have the engine out because I want to do this as right as I can with my budget. This will be a semi daily driver. So far parts I've gathered..or are on order
Huron Speed V3 turbo kit with 7875 Turbonetics Turbosmart BOV 50mm Turbosmart hyper-gate 45 Wastegate Tick stage 2 Turbo cam / springs DOD/AFM delete mightymouse catch can Tru-cool 40k trans cooler My questions What is the recommended ring gaps? I plan to put my oil drain in drivers side front of oil pan, is that a good place for a 2010 4x4? My truck has the factory oil cooler, where does my turbo oil feed line come from? What torque converter should I run? I've been told a Circle D Pro billet single disk anywhere from 3000 - 3600? I'm sure to have more questions going forward but thought I would start here. |
gaps - mid to high 20s, ask your tuner what he thinks too
i would think the passenger side front. your turbo will be on the pass side right? Mines on the Pass side front side of the pan too. Trick Turbo sells a piece that you need to keep your oil cooler and have a feed line to the turbo. That TC would be fine. I like my 3K stall but a lot of other guys with similar trucks like theirs to stall higher. |
Ring gaps should be in the ballpark of .026 if you plan to daily it as you mentioned. looser of it was more of a toy.
As far as a converter is concerned I would look at a 258 or 265mm in about a 3000 range. |
Have Chris at Circle D spec one out for you.
^^ Times two, Chris @ Circle D knows his shit
Thanks guys...I went with the Circle D Pro single disk 3400-3600 and gapped all top rings to 25..they were all right at 18 when I started.
