Torque converter selection
I'm in the process of building a 2010 Silverado RCSB 4x4 turbo truck. It's a low mile 5.3l with the 6l80 trans. Right now I have the engine out because I want to do this as right as I can with my budget. This will be a semi daily driver. So far parts I've gathered..or are on order
Huron Speed V3 turbo kit with 7875 Turbonetics
Turbosmart BOV 50mm
Turbosmart hyper-gate 45 Wastegate
Tick stage 2 Turbo cam / springs
DOD/AFM delete
mightymouse catch can
Tru-cool 40k trans cooler
My questions
What is the recommended ring gaps?
I plan to put my oil drain in drivers side front of oil pan, is that a good place for a 2010 4x4?
My truck has the factory oil cooler, where does my turbo oil feed line come from?
What torque converter should I run? I've been told a Circle D Pro billet single disk anywhere from 3000 - 3600?
I'm sure to have more questions going forward but thought I would start here.
Turbosmart BOV 50mm
DOD/AFM delete
My questions
gaps - mid to high 20s, ask your tuner what he thinks too
i would think the passenger side front. your turbo will be on the pass side right? Mines on the Pass side front side of the pan too.
Trick Turbo sells a piece that you need to keep your oil cooler and have a feed line to the turbo.
That TC would be fine. I like my 3K stall but a lot of other guys with similar trucks like theirs to stall higher.
