timing with higher than normal boost
Old Sep 8, 2010 | 09:18 AM
Spoolin's Avatar
GFYS and STFU
Yeah, I was gonna say the same as Kyle, Parish always preferred more boost to more timing. He was running 22 psi I think with conservative-ish timing.
I'm curious about the OP's mid-mounted turbo, is that Trick's set-up?
Old Sep 8, 2010 | 10:23 AM
smokeshow's Avatar
Mod with training wheels
Originally Posted by kbracing96
Actually Jake, If I remember right, Parish came to the same conclusion Chris did, More boost is better and safer then more timing. Chris's truck is a bit of a dyno queen, Last time I talked to him he had well over a 100 pulls on the dyno with it!
PS, you need more timing on your truck,
So Todd lied to me! Lol, we talked about that a few days ago. I need to dig up the threads and read up on what exactly he did. (links?)
I have some more timing coming in the mail. AlkyControl
Old Sep 8, 2010 | 05:08 PM
kbracing96's Avatar
Yep! Damn Todd, Think of it like this... Timing only helps you burn the fuel and air you already have more efficiently. Too much timing will result in less power as now too much of the burn is happening BEFORE the piston goes over TDC and into the power stroke. It can also lead to to high of combustion pressure which will cause the fuel mix to explode instead of burn (detonation).
Now, when you add boost, your adding fuel too, so you have MORE fuel and air to burn in the power stroke, so with the proper timing, you will always make more power with more boost.
Old Sep 8, 2010 | 06:19 PM
smokeshow's Avatar
I thought about that quite a bit and figured there had to be a sweet spot for timing. I looked into it and found that most NA engines sweet spot is at 28° timing, motors on boost a little less. I just need to get a bit closer to that sweet spot.
Old Sep 8, 2010 | 06:41 PM
Atomic's Avatar
I have a gauge for that
im at 19 degrees and havent tried any more with my 11:1 408 and 7.5 psi
Old Sep 8, 2010 | 09:00 PM
05stepside's Avatar
It's a shortened STS kit with turbo right next to trans.
Old Sep 8, 2010 | 11:55 PM
2ktransam's Avatar
Kyle, I have 104 dyno pulls to be exact. The key is to find the sweet spot for timing at each boost level. For some reason my truck loves 19-20 degrees of timing at anything over 8psi. I have tried 22 degrees at 14psi but it didn't pick up anything so I left it at 19 and called it a day. I would not try anything over 16-17 degrees without meth and 93 octane. Next time I put it on the dyno I'm going to run the timing up a little more at a safe boost level like 10psi and see what happens.
As for being a dyno queen. I ran for the first time in over a year tonight and went 11.90@113 with only 11psi and 2000'DA. Next week I'm going to shoot for 10's.
Old Sep 8, 2010 | 11:58 PM
2ktransam's Avatar
Damn, you sound smart. I will concur with your statement.
Old Sep 10, 2010 | 11:27 PM
La Chochita's Avatar
Im pushing 13-15 psi with 17*...93 oct.+Meth...a lil over and ill get KR. Its at stock compression 9:4.1.
Old Sep 11, 2010 | 12:13 AM
2ktransam's Avatar
I ran mine tonight at 14psi and 20 degrees of timing. 93 octane and meth with no knock. Had me a little worried but it made it through.
