Thermost worth it for FI?
Old Jul 25, 2006 | 10:32 AM
Wilde Racing's Avatar
How do I change this text
well I went the cheap route and bought a pack of BB's.... We'll see I guess.
Old Jul 25, 2006 | 12:38 PM
parish8's Avatar
single digit dreamer
most people with fi do the stat mod. my truck holds steady at 178-180 with the 160stat.
Old Jul 25, 2006 | 12:50 PM
Mort's Avatar
Cool
My 160* is the same - runs 175* to 180* . It may heat up a little more when sitting in hot temps or when doing WOT runs.
A 160* stat begins to open at 160* and should be fully open at 175* which seems to be what people are seeing. Ran mine all winter with no problems and had lots of heat inside the cab.
Old Jul 25, 2006 | 12:53 PM
99/5.3w/hips's Avatar
Ive said this before and I will say it again. I really do not understand this mod much. I have a stock tstat and my temp stays pretty consistent @ 185* even in 110+weather in the central valley. What is 10-20 degrees really going to do?
Old Jul 25, 2006 | 01:17 PM
Mort's Avatar
Cool
How are you measuring your ECTs? If you are using the instrument cluster gauge it may not be accurate.
The stock thermostat in my truck says it is a 86/100*C or that it opens at 86*C and is fully open at 100*C and my cluster gauge always read just under 100*C. It now reads just over 75*C.
75*C = 167*F
86*C = 187*F
100*C = 212*F
Logging software says my engine ECT is between 175*F and 180*F under normal operating conditions with the 160* stat. I never logged the stock stat but I think I am running 30*F to 35*F cooler with the 160*F stat. That in turn means that my engine is running that much cooler and less prone to detonation and that means I should be able to run a little more timing and/or boost or maintain a larger safety margin.
Old Jul 25, 2006 | 03:13 PM
logging with HPtuners...says 185* ect most of the time...very rarely goes over that...just kinda warms up to that and stays at that...if ive been driving a lot on a hot day it might say 190*
Old Jul 26, 2006 | 09:08 AM
Mort's Avatar
Cool
Well that does not sound like stock operating temperatures to me but I am not exactly sure what a 99 should run. It sounds like your temperature sender is reading low or you stat has been changed out for a 170* at some point in time. One way or another your operating temps appear to be 20*F to 25*F below stock already so no worries enjoy.
Old Jul 26, 2006 | 09:30 AM
Superado's Avatar
11 Second Truck Club
definitely not stock...
also...these temp reducing additives...varying in price from probably $7-$25ea...have tried the RP and the new "Q"...must only work with water only applications or at most a 15% mix...I have seen absolutely no reduction in temp.
Old Jul 26, 2006 | 11:30 AM
well it must have been done when I bought it then because I havent swapped it. I thought it was completely stock when I got it except for exhaust but I guess not.
Old Jul 28, 2006 | 04:52 PM
TURBHOE's Avatar
mine use to run 220 or better. overheated al the time too. so i went to a 160 and the bigger 34" core radiator and 05 efans. now its 175-180 all the time
