Is there a difference between the truck 6.0 and the truck 6.2 exhaust manifold?
Old Sep 20, 2009 | 09:03 PM
ss1le02's Avatar
Default Is there a difference between the truck 6.0 and the truck 6.2 exhaust manifold?
ANy difference? Do the 6.2s flow better.
Old Sep 21, 2009 | 12:08 PM
Allgonoshow's Avatar
can't say for sure but likely.
the convertor and exhaust tubing is bigger so the discharge on the manifold is likely bigger as well.
you would probably need to change the y-pipe to match.
Old Sep 24, 2009 | 08:28 AM
actually have a 6.2 in my shop today for headers,
the manifolds on the 6.2 are the same as 6.0
2.5 inch discharge
Old Sep 24, 2009 | 07:24 PM
Matt G6007's Avatar
the difference between the 6.0 and 6.2 is the cam is slightly bigger from the factory, the heads flow way more the valves are 2.16 intake and 1.59 exaust and the runners are 260 cc intakes and 90 cc exaust and the intake manifold is different, and the intake rocker arms are offset to the side, the bore of the motor is bigger and the compression ratio is 10.5 to 1, and it has a 58X reluctor wheel v.s the 6.0s 24X reluctor wheel
Old Sep 7, 2020 | 07:35 PM
06-6.0's Avatar
Registered User
Default Question
2.5 inch discharge
is the bolt pattern the same? And is the flow of them any better or about the same?
Old Sep 7, 2020 | 07:46 PM
FFDP's Avatar
Everything is the same. Bolt pattern and flow.
07Softail
Jan 31, 2017 08:54 PM
15dnali6.2
Nov 21, 2015 09:25 PM
Choda
May 30, 2014 10:25 AM
NATASILVERADO6.2LTZ
Nov 10, 2010 12:46 PM
