SuperTurbo charged GMC
Old Apr 24, 2010 | 04:25 PM
  #31
408superturbo's Avatar
One other lesson on posting pictures, whenever you past a link to each picture hit the enter button to go down to the next line so all the pictures dont stick together and make the page wider. That way they will be one under the other like I edited your post to look like.
Good lookin truck by the way
Thanks for the info and comments. The truck was made at the ft wayne indiana truck and bus plant and its the same color as the highway dept. trucks. I just changed the blower pulley from the 3.5" to a 5" and it definetly helped I can definetly push the pedal further ! I still have the overdriven balance on it- its easier and cheaper to have blower pulleys made then to change back to 6 ribs.
Old Apr 24, 2010 | 05:35 PM
  #32
smokeshow's Avatar
Mod with training wheels
What's the blower putting out with the 5" pulley?
Old Apr 24, 2010 | 05:51 PM
  #33
I dont know yet but remember the balancer is much bigger. 3.5" was 13.5lbs
Old Apr 25, 2010 | 04:19 AM
  #34
Spoolin's Avatar
GFYS and STFU
WOW, incredible truck!! And like Kyle said 4wd to boot!!!
I'm wondering if he can put all his power down to the ground if he can break into the 9's like Jarrett did! 20lbs of boost on a 4wd 408...it's gotta be low 10's high 9's!!
Awesome work man! Get the bugs worked out already!!
Old Apr 27, 2010 | 06:50 PM
  #35
acethedragon's Avatar
honestly wouldnt worry to much bout the turbo being small. the way your compounding is the correct way. small turbo to feed the supercharger, which then compresses the air futher. i know its not quite the same but diesels do it that way - small turbo to get up quick feeding a larger turbo to keep up on top. get the wastegate situation settled and you should be fine. looks like a blast to drive.
Old Apr 27, 2010 | 07:12 PM
  #36
ForcedTQ's Avatar
Lightbulb
So, could the small turbo's exhaust housing be causing a restriction in the exhaust path? I understand the intake path theory, it sounds like exhaust restriction causing exhaust gas reversion back up the intake tract, subsequently increasing boost but doing nothing for HP/TQ. Am I thinking correctly on the exhaust side theory?
Old Apr 27, 2010 | 07:20 PM
  #37
Stoichiometric's Avatar
Nice looking set up. Do you know the EGT and drive pressure numbers?
Old Apr 27, 2010 | 07:28 PM
  #38
Reversion won't increase boost. Think of what is happening is 60k people in the ballpark stadium are all trying to exit through one set of revolving front doors, the doors are going to spin uncontrollably fast until you open up some alternate routes(larger/additional wastegates) or increase the size of the doors(larger turbo/exhaust housing).
Old Apr 27, 2010 | 08:09 PM
  #39
Spoolin's Avatar
GFYS and STFU
I was kinda hoping you'd chime in henry!!
Old Apr 27, 2010 | 08:26 PM
  #40
kbracing96's Avatar
I guess I just don't under stand your thinking here... A small turbo in this setup is like having a big supercharged motor sucking though a small straw and then trying to blow out that same small straw...
