supercharger vs. turbo
Old Nov 17, 2006 | 08:16 PM
nightrunner's Avatar
Mr. Obvious
forget about the ls7 unless you have tons of money, not just for the initial price of the motor - $15k (somewhere's in that price range) but also for the cost of converting the truck to a dry sump oil system
you will also need to convert to either an 80e or a t56 ( with extreme duty clutch)
a better option would be a ls2 stroker - 402 or a lq9 stroker - 408 built for lower compression to crank up the boost
a supercharger has more lowend tq and turbo has more hi-end hp however the turbo might be better for a dd 2wd because of the traction problems you will have
Old Nov 17, 2006 | 08:59 PM
Stoichiometric's Avatar
If you have the coin, build up a GMPP iron block for some turbos.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
2500ZL1
Jan 25, 2016 06:30 AM
therock
Jul 25, 2015 09:23 AM
Ammadien
Jul 22, 2015 08:50 PM
