supercharger ?
I have a sidemount magnacharger and I'm trying to find out where I can buy a smaller pulley from becaues I would like to run around 7 to 8 of boost and if I do this will I have to buy a new belt? Also has any one done methanol injection systems or fmic on this kit or one like it. From the way that it bolts up I think that I'm going to do the meth kit but I would rather do Fmic but it look like it would but very hard to do. I'm also trying to find out if a meth kit would mess up a dry nitrous shot. I'm not going to put nitrous on it for a while but one day I'm sure I will. It will be after a cam, springs and a stall at the least.
I'm not sure about where to get the pulleys, but I would go with the meth injection. Its a lot easier then building an intercooler setup and will have similar results with the added benefit of higher octant when you need it under boost. As far as with a dry NO2, it shouldn't affect it, you really won't need to spray both at the same time any way, because the NO2 will have the same cooling affect as the meth.
