STS oil pump
Old May 20, 2006 | 12:45 PM
blue00silverado's Avatar
Default STS oil pump
heys guys, how exactly do i test to see if my pump kicks into high mode. a little lost on this, thanks
Old May 20, 2006 | 01:25 PM
TIM Z's Avatar
11 sec. Truck Mod
you take a wire and jump the switch that is hooked up to the solenoid valve on your engine manifold.just take the wire and touch the 2 screws together where the blue and brown wires connect
Old May 20, 2006 | 01:34 PM
where is the selenoid valve located at.
Old May 20, 2006 | 01:49 PM
kenihemi's Avatar
I just posted on your other thread. What did you get with your kit?
Did it include the wiring, pressure switches, installation manuls, etc?
Old May 20, 2006 | 02:47 PM
yeah got it all but i just dont want to screw this up,
Old May 20, 2006 | 04:29 PM
Mort's Avatar
Cool
The solenoid valve and hoobs switch are located on the passenger side of the engine between the intake manifold and the head. the hoobs switch is connected to the nipple at the rear of the throttle body and senses boost > 1 psi. This operates the solenoid and puts the oil return pump on high speed. The hoobs switch has 2 brass screws and to test you jump a wire across them with the engine running. Get a friend to listen and see if the return pump speeds up.
You should be able to hear and feel the solenoid click when you jump a wire across the hoobs switch.
5.3Okasai
Mar 9, 2022 01:07 PM
pupi305
Sep 14, 2015 11:40 AM
JordanH
Aug 8, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
