STS - oil pressure
Old Oct 11, 2005 | 09:50 AM
Wilde Racing's Avatar
How do I change this text
I have never heard my alarm, maybe I should test it like it said to in the install instructions? lol
Old Oct 11, 2005 | 09:53 AM
haynSS's Avatar
thanks for the info guys. Yeah i see mine going off just about 8-10#s as well, very very annoying, i havent gotten over 10#s yet since I got my turbo back but it stayed on until 15#s before.
Old Oct 11, 2005 | 10:35 AM
TG02Z71's Avatar
Is this really a flow issue that can be resolved or is the buzzer going off just BS??
Old Oct 12, 2005 | 05:10 PM
Originally Posted by TG02Z71
The buzzer only comes on if your pump is not getting any oil. Its really an alarm from what the install booklet said.
Check this out.
http://i8.photobucket.com/albums/a18/tg02z71/Page7.jpg
You have it backwards. The buzzer goes off if more than 3psi of pressure builds up the return line. There is a pressure switch next to the pump that is set at 3psi. Normally with bigger turbos and higher boost, it will go off under sustained boost. You can pull the small rubber plug out and use an allen wrench to turn it up some, although I wouldnt do it much. STS does offer a high flow oil pump that will help also.
Old Oct 12, 2005 | 06:56 PM
haynSS's Avatar
I have that high flow oil pump and the most they have recommended me do it is 3/4-1 quarter turn. I believe the size of the allen wrench is 7/32.
makani
Old Oct 12, 2005 | 07:05 PM
TG02Z71's Avatar
Thank you for the correction. The directions in the STS kit leave allot to your imagination. I wish they included information for advanced tuners and users.
Maybe I should call and see if they have anything for their recommended tuners and STS dealer/installers.
Old Oct 13, 2005 | 08:20 AM
kenihemi's Avatar
Maybe its a different setup in the hemi's from the others. Mine works like I described earlier and its a 1lb hobbs. It shorts the contacts when it does not see oil pressure coming from the pump on the return line.
Old Oct 14, 2005 | 05:12 PM
vanillagorilla's Avatar
My kit came with a switch to control the speed of the pump. If your kit came with this too, then you might try switching pump speeds to see if that helps.
Old Oct 16, 2005 | 07:58 PM
ktmrider's Avatar
The Dodge kit has two Hobbs switches on the pump circuit, one to activate the pump high(er) speed mode when "higher" boost is seen, plus one on the pump unit itself that activates the alarm. Both are adjustable like mentioned with an allen wrench. Clockwise will increase the switch engagement threshold. STS does not suggest playing with these but if you use common sense and remember where you started it is no issue ( we had to adjust the one for the extra injector on ours ).
I THINK it is tripped when excess pressure builds up on the turbo side of the pump ( the switch is located inline before the oil reaches the pump ). They are push style pumps and do not pressurize the oil going into the turbo and rely on gravity to feed the oil to the pump.
Again this is the Dodge kit, and I am not familiar with the GM kit so it might be different. If it is the same, make sure to adjust the switch on the pump assembly itself, not the high/low speed one.
Texas5.3_1251
Mar 5, 2016 08:10 PM
69z-28
Sep 21, 2015 07:31 AM
Go5.3tt06
Sep 14, 2015 02:11 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
Boyes50
Sep 8, 2015 12:06 PM
