STS and oil cooler ? Help
Old Apr 1, 2007 | 06:34 PM
2500HD6.0's Avatar
Default STS and oil cooler ? Help
I was under my truck looking at the oil tap spot and there are 2 steel oil lines coming out of the top of it for the oil cooler but on the tranny side of the plate there is what looks to be a plug. My ? is can I just hook in it this or do I need to tap the bottom of the block off plate. If so how do you disconnect the steel oil lines?
I also have a drive shaft in my way should I take in down to do this?
Old Apr 1, 2007 | 06:37 PM
BlownChevy's Avatar
blownerator
25 Year Member
do you already have the STS kit?
Your kit will come with an adapter like this:
hard to see it, but it will sandwich between the cooler lines and the filter housing.
Old Apr 1, 2007 | 06:50 PM
2500HD6.0's Avatar
I bought a used kit that was on a truck without factory oil cooler so I don't have an adapter.
I'm not sure what you’re talking about in the pic. are you running an oil cooler on your truck?
I wish I had my camera with me
Old Apr 1, 2007 | 06:54 PM
BlownChevy's Avatar
blownerator
25 Year Member
I know what the oil cooler set up on yours looks like...i wish i had taken a closer pic. If you call me on monday, i should be able to get you the parts you will need to do this the right way.
Old Apr 1, 2007 | 07:52 PM
kbracing96's Avatar
From what i remember, trucks that have the oil cooler, you have to drill and tap the bottom of the oil line block. Its kind of a pain, cuz I don't think you can take it off, cuz the oil lines are welded to the block. I'm sure it will be easier if you take the drive line out. Then just use a 90* 1/8 pipe fitting to clear the drive shaft.
Old Apr 1, 2007 | 08:12 PM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by kbracing96
From what i remember, trucks that have the oil cooler, you have to drill and tap the bottom of the oil line block. Its kind of a pain, cus I don't think you can take it off, cut the oil lines are welded to the block. I'm sure it will be easier if you take the drive line out. Then just use a 90* 1/8 pipe fitting to clear the drive shaft.
I think they changed that, not 100% sure though.
Vortec350ss
Jan 12, 2016 10:36 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
nabozny21
Oct 17, 2015 07:47 PM
lxcoupe
Sep 25, 2015 12:36 PM
