STS exhaust suggestions
Old Nov 16, 2006 | 09:07 PM
ogkevin13's Avatar
Banned
no muffler no cats if u want to sound like a jet hehe
Old Nov 17, 2006 | 06:55 AM
slowec's Avatar
Originally Posted by spinz71
Whatever you use, make it big! What happened with mine is that it created boost creep. The exhaust is a restriction and it will cause backpressure all the way back up. I have an 8psi spring but with the exhaust I get 10 psi. I have a 3.5 inch dynomax race (straight thru) welded to the turbine exhaust pipe and dumped over the axle.
A more restrictive exhaust will help not hurt your boost creep problems. I had a STI and stock exhaust were ok , but Big aftermarket units without enough backpressure allow the boost to creep up due to the lack of B/P. If you research this and find me to be wrong, call me on it. No one person knows it all. This is the way I understand it.
Ogkevin, Hows that hideaway intercooler workin out?
Old Nov 17, 2006 | 09:20 AM
spinz71's Avatar
I'll admit I'm not sure how it works. What I do know is that I had the about 10-12 inches of straight pipe after the turbo and was at 8 psi. I put on 21 inches of 3.5in. muffler and a turndown and it went to 10 psi. Nothing was else changed. I can't imagine that being less restrictive. But this truck is so weird it doesn't surprise me.
Old Nov 17, 2006 | 10:10 AM
YenkoST's Avatar
Slowec....I'd say go a single 3.5" all the way out....3" would almost be too small for a turbo. The D-max uses 3.5". Its not about power necessarily but the EGTs.
Old Nov 17, 2006 | 03:56 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
As I said above, I used a dynomax camaro muffler.
Haven't been able to log in in daaays!! Damn internet pipes must be filled up with gambling chips.
Old Nov 17, 2006 | 05:13 PM
hrodgmc's Avatar
I had a 3" in/outlet dynomax rv bullet muffler on the sy. It was quiet at part throttle and roared at WOT. Lack of b/p causes boost spike/creep and excessive b/p can also cause it too. (had a magnacharger with a 8psi pulley see 12psi with a 2 into 1 muffler.)
Old Nov 29, 2006 | 11:39 AM
Big Thumper's Avatar
Lowering backpressure downstream of the turbocharger increases the effective expansion ratio across the turbine, resulting in higher turbine efficiency / more turbine output power for the same massflow and temperature.
This will generate more boost if your wastegate / boost controller is not functioning properly, as the turbine can drive the compressor harder.
First post on here - work with this stuff for a living, thought I'd chime in.
- Matt
Old Nov 29, 2006 | 02:26 PM
slowec's Avatar
Dynomax ultraflo bullet from summit (3"), $hitty bend for a turndown . Just welded this up a minute ago. I'll post how it works out.
Old Dec 3, 2006 | 06:29 PM
turboescalade's Avatar
Default no muffler
http://youtube.com/watch?v=N0IztgcOi24...
check out this link... this is my cady.. I run 3 inch exhaust straight thru... 3 inch after into a 5 inch diesel tip... it makes it echo.. sounds absolutely amazing.. no muffler, still have the cats
Old Dec 3, 2006 | 07:02 PM
slowec's Avatar
Thanks for the replies. I welded the setup on tonight. I am gonna remove the cats later, but now it is so quiet. i don't know how the boost was affected . Just drove it home.
