spraying intercooler
Old Sep 28, 2007 | 08:01 PM
WJ MARK's Avatar
Originally Posted by Slowhawk
Don't waste your $$. You sig says you have meth.If it's 100% meth your all good.Spraying the intercooler is for the imports.
Hey I spray my intercooler! But pretty much just for when Im towing , and towing in traffic. Plus i had mine before the meth. IM NOT A ****** RICER. He he J/K im not offended.
Old Sep 28, 2007 | 08:45 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Liquid nitrogen or go home....I was thinking about this the other day after watching something on the tv about how cold nitrogen is. Spraying the heat exchanger in my case...
Old Sep 28, 2007 | 09:04 PM
WJ MARK's Avatar
It would have to be liquid nitrogen, but that would probably freeze it and make it break into pieces. Compressed nitrogen is not cold at all when it comes out of a bottle.
Old Sep 28, 2007 | 09:14 PM
TG02Z71's Avatar
If the nitrogen was sprayed into a fog it would be ok, but any more concentrated may cause things to shrink
then get frozen moisture between fittings,
then have water between fittings after warming up and possibly blow off some connections??
Sounded like a rocket scientist answer when it popped into my head, must be the beer talkin!
Old Sep 28, 2007 | 10:45 PM
05crew's Avatar
yes im spraying 100% meth, but i dont have a intercooler on yet and my maf is take out timeing. i think the intercooler and meth will help out a lot. just a thinking of things to try if it does not work. thanks for the info
Old Sep 28, 2007 | 11:29 PM
Stoichiometric's Avatar
If you run 100% meth injection you can get away with pretty high IATs before your timing suffers if you do your own tuning. I see 150*+ with 24* timing and no knock. Lower IATs are always better and will make more power, but at the cost of an additional system on the truck.
Old Sep 29, 2007 | 06:58 AM
slowec's Avatar
Nitrous goes in the intake! Ask trever1t
Nitrous spray bar =
Old Sep 29, 2007 | 09:03 AM
Quik's Avatar
5 year bitches!
i kicked the idea around of spraying the intercooler...yes it is used on imports but some of them have excellent results
Old Sep 29, 2007 | 09:44 AM
WJ MARK's Avatar
I would hook up your purge to a spraybay and then spray the intercooler.
Old Sep 29, 2007 | 04:14 PM
05crew's Avatar
the meth is after the maf, so it does not see the cooler IATs, im going to cut the IATs and move it after the MAF so it will see the the cooler air.
