spooling ?
Old Sep 9, 2007 | 10:52 AM
05crew's Avatar
Default spooling ?
i took my truck to the track for the first time, and i could not get it to spool right on the line, saw about 3 lbs. but off the track i can get to 5-6lbs. do you see the same or what am i doing that is not right. also when the truck has cooled down between runs it will not spool right. do i let it cool down or what. first sts kit for me, trying to get it right.
1/8 mile 9.44 with no FMIC or meth.
Old Sep 9, 2007 | 11:50 AM
Mort's Avatar
With my truck I stand on the brake so it will not move and bring the revs up to the converter stall speed and let the boost build to about 5 or 6 psi and let the brake go and floor the gas. On logs I see a throttle position angle of about 47% to 50% and RPM of 2900 to 3000 rpm. When my boost was lower I would see a stall speed around 2500 rpm but with 10+ psi I see around 3000 rpm brake stall speed. I am sure it takes longer than the lights allow so if you can ignore the lights and build boost to your desired level and go then great. If the lights time out on you then I guess you will have to work within the time they allow.
Good luck and have fun.
Old Sep 9, 2007 | 03:30 PM
ZO6Ted's Avatar
Is your exhaust wrapped? Leave your truck running between rounds, don't turn it off and it will stay warm and spool much better. On the street it's already warm, that's why it's easier. Trip the pre-stage light, then start spooling, pump your brake to trip the stage light and continue spooling until time to go. Happy racing!
Old Sep 9, 2007 | 06:36 PM
05crew's Avatar
no my exahust is not wraped. sts said i dont need to what do you think. and also im boost my crank case. i have a check valve in the pcv, but i dont have one in the line from the valve cover to oil pump switch to the port behind the throttle body. do i need one here?
Blue03sss
Mar 7, 2019 05:06 PM
jscherbs
Mar 24, 2017 07:20 PM
turbo6c3
Oct 5, 2015 06:11 PM
fastjweb
Aug 31, 2015 09:57 AM
