Spark plugs?
Old Sep 28, 2009 | 07:32 PM
zittman's Avatar
Default Spark plugs?
Putting new engine in with mods. I was wondering on what spark plugs and heat range to run. It is a new 6.0 LQ4 with a Vortech Supercharger with a 2.87 pulley, water to air intercooled, Comp Cam Texas Speed .581-.591 lift and .224-.230 at .050 on 114lc. patriot springs, smith brothers pushrods, 90mm throttle body, 75lb injectors, AEM Bruteforce full length headers, no cats, 2.5" duals into 50 series flowmaster muffler. Should run around 12-13lbs of boost. Plan on running Devils Own Stage 2 meth kit in the next month after it is running. Tuned by Justin at Black Bear. Any ideas??
Old Sep 28, 2009 | 07:40 PM
Mangled03gmc's Avatar
Baltimore Whore
Justin will prob tell you to keep the tr 55's in there. Otherwise most of the guys are running the TR-6 plugs. I am however running the 55's
Old Sep 28, 2009 | 08:20 PM
zittman's Avatar
The 55's are hotter than the 6's correct? What is stock??
Old Sep 28, 2009 | 09:05 PM
nonnieselman's Avatar
TR55s are comparable to stock.. TR6s are the next step colder.
Old Sep 28, 2009 | 10:10 PM
TX Tahoe Z71's Avatar
I'm using TR-6 at .035", it's a step colder than TR-55
Old Sep 28, 2009 | 10:56 PM
terravast4's Avatar
TR-6 at.035
Old Sep 29, 2009 | 10:33 AM
zittman's Avatar
Thanks for the info. I will start with the TR6's and go from there.
Old Sep 29, 2009 | 03:39 PM
Rick_Vor's Avatar
Originally Posted by terravast4
TR-6 at.035
Ditto. They look excellent after 30k miles of 10lbs in a daily driver.
Old Sep 30, 2009 | 09:48 PM
Midnightrider's Avatar
im using tr-6 at .035 as well
Old Sep 30, 2009 | 10:06 PM
Ender06's Avatar
TR-6 at.035
same here
