Smallest/fastest spooling turbo for stock 5.3? 400-450hp
Old Sep 25, 2022 | 12:27 AM
RDF1's Avatar
DuNnO
5 Year Member
Originally Posted by Fullpower
Huron Speed says Borg S366 is no-go on their manifold/downpipe.
Given choice between VSRacing 70/70 Billet Gen2 and a AGP Z2 65-65 Billet Which one would give LONG TERM daily driver service on a 5.3 in stock geared (3.73 ) Suburban...?
Looking for good driveability, quiet stock-like exhaust quality, and around 500 ish horsepower on LOW Grade gasoline.
Cam is a TSP 208/214 .550" stock compression. Not looking to set any records, never going racing, just want to have a bit more steam under the go pedal.
Best easily available road fuel here is nominally 90 Octane, but outside the big cities, and off the PAVED roads, 87 octane is all you can find.
For absolute long term reliability .. Borg Warner.
Your not going to get 500hp on 87 octane. My 1991 truck with a S475 on a 5.3 i was able to run 87 octane on 6psi but had to pull a ton of timing to keep it happy compared to 93 octane.
It would be ok for daily driving and if the tune is good you could haul with it.
On my original turbo truck all i ran was 93 cause it wasnt expensive back then. 6-8psi was about perfect for towing and Daily driving.
Old Sep 29, 2022 | 01:44 PM
Chrisbequick's Avatar
Yes, he can. He just needs more boost and fuel.
Old Dec 9, 2022 | 08:15 PM
Fullpower's Avatar
I have PLENTY of fuel.... and not scared of manifold pressure.
Most retail pumps IN THE CITY have 90 octane, but down the highway, out of town, the little card-lock trucks stops for damn sure only have a single pump for gasoline, and it's 87 octane.
SO, I would build and TUNE my Low octane table for continuous safe operation at 87 Octane, and, presumably my high octane table would take advantage of my NORMAL operation on 90 octane.
. Probably should be possible to make good power, driveability and not stress lower end components within the range of 10 to 12 PSI manifold pressure.
Still comes back to an ideal choice of single turbocharger for ROAD use in a heavy vehicle, presumably a smallish compressor will be enough for a 5.3 Liter that doesn't plan to race, nor spin much RPM in normal use.
Would an AGP Z2 62/65 or 65/65 be UNDER size ?
Old Dec 10, 2022 | 12:49 AM
RDF1's Avatar
DuNnO
5 Year Member
ever tuned a turbo 5.3 on 87 octane? Its crazy how little of timing they will take even with a cold plug. Can't imagine how high EGTs get.
Old Dec 10, 2022 | 12:50 AM
RDF1's Avatar
DuNnO
5 Year Member
I would rather a larger turbine for that to keep backpreasure down. But a S366 works very good and builds boost fast.
Old Jan 6, 2023 | 03:07 PM
Fullpower's Avatar
For a mild 5.3 liter, daily driven 4x4 does this look like a good pick for a Huron Speed V4 kit ?
Precision 6766 HP CEA
Old Jan 6, 2023 | 11:15 PM
RDF1's Avatar
DuNnO
5 Year Member
As long as you dont want to spin it to 7000 rpms. it will be good.
Old Jun 12, 2024 | 11:48 PM
Fullpower's Avatar
Settled on VSR 7875 Billet.
Installed on Huron Speed manifold. 5 heat cycles, 6 coats of VHT flat black ceramic paint on Turbine.
Need to make a few ECM connections: 4L80 VSS pins, Electric fan pins, and IAT sensor. six wires to poke into the PCM, and then plug in some Deatschwerks 60# injectors. Getting close to TUNE-Time.
Old Jun 13, 2024 | 12:20 PM
MikeGyver's Avatar
Old Jun 26, 2024 | 07:18 PM
Fullpower's Avatar
VSR 7875 is driving okay, idling pretty smooth with the Deatsch 60#
Havent gone too heavy into throttle yet, 140 kPa is holding good safe AFR 11.4 with the STOCK fuel pump, which is ... Kind of hard to believe.
Need to drop the AEM 340lph in there before I melt any pistons.
