Small turbo build what do you guys think?
9 Second Truck Club
Dont forget this is an SUV and it weights over 5500lbs i have 24 inch rims on it. (100lbs per wheel/tire)so there is some MEATunder all four, so it should hook up a little. .lol
As far as maxing out the turbo. I have read specs on the turbo and it says its good for 1150HP. IS that not true?
I think you are just screwed cuz the high altitude. The guy that is doin the build says 20lbs easy from the 76. The 88 would bring lag problems wouldnt it?
oh and its full time AWD with the power sucking 4L80E under there too.
As for the track times I know that you are AWD 5500LBS. Those heavy wheels are going to hurt, and need to go, but I still think a 4000RPM 14PSI launch with 4 light weight 28" tall ET streets could go low 11's to high 10's with that 408.
Im also running a power sucking 4L80E/ Autotrack transfer that spinns the front driveline all the time. You could allways pull the front shaft on the dyno.
9 Second Truck Club
How do I change this text
Tuning dependent, I think you'll be in the 800 rwhp park. add meth and some cam specs maybe higher...
9 Second Truck Club
Seams strang.. I could hit 15 psi with a gt-67 on my old 6.0, didn't matter if I was at 4,000 foot or sea level, though it did spool better at sea level. Hell, I hopeing it will do more...
The monster is almost done. Hoping to pick it up Friday. It should be dynoed Thursday anybody wanna guess what its gonna make?
Will post dyno sheets as soon as I get em.
https://www.performancetrucks.net/fo...=411978&page=2
You can see the rest in person....
