Safe boost with no meth?
Try changing your oil if its at all old, My 05 5.3 lm7 I believe I knicked a bearing swapping cams, truck used to have 50lbs at idle cold and about 40 hot idle with 5w30, i swapped cam and added s/c and I noticed my oil pressure would be more like 35-40 cold idle and as low as 15 hot. no ticks or funny noises, I dropped the oil since it had about 4k on it, tossed in some 10w30 pennzoil and now it idles at 45-50 cold, 25-30 hot idle and 45 cruiising where i could barely break 25 cruising. oil must have been broken down. i know its still low for a 5.3 I will just have to wait and put in a 6.0 or a l33 before i solve the lower oil pressure issue completely..
every car is different. some like timing and some dont. most people over fuel the motor and over time it. i dont run the vent pipe on my camaro and that makes 1500hp, at the tires
I just picked up a manual boost controller so I can start turning up the boost on my truck. Right now it is only running 6psi with 14* timing. I know 9-10psi is safe as I've done it previously but what about 12-15psi with no meth on 94 octane pump gas?
It is a stock 5.3L with cam, head studs and ls9 head gaskets, br7ef plugs, master power 76.
