ring gap for LY6 with boost
Old Jul 14, 2015 | 07:11 PM
Gadgetized's Avatar
Default ring gap for LY6 with boost
I'm am getting close to assembly for my LY6, and thought I would get some input from people that have been there. I have pretty much stock everything and was wondering what I should gap the rings at. Right now they are at .026 top and .028 bottom. I will be running pump gas a majority of the time at about 15 PSI. Occasionally I will add E85 and turn the boost up to maybe the low 20's. I would like to break 900 at the ground. Does anyone that has been there before think I should be using a different gap?
Old Jul 14, 2015 | 08:08 PM
RS/SS 4.8's Avatar
10 Second Truck Club
Mine are setup exactly like that from my machine shop after talking to em about what i wanted to do with my 370 if that helps any.
Old Jul 14, 2015 | 08:23 PM
Gadgetized's Avatar
Thank you. That's where I have them on my 370 too. The one thing I wonder about is the LY6 has a thinner top ring than my Wiseco's or even stock LQ4's. I have heard of people going less and people going more.
Old Jul 14, 2015 | 09:14 PM
George C....'s Avatar
Formerly ScreamingL
Ly6 makes over 1000 rwhp gap are .028 and .028
Old Jul 14, 2015 | 09:22 PM
Gadgetized's Avatar
^^^ Thanks, that is the info I was looking for. I was just stumbling across your TT Notch build.
Old Jul 14, 2015 | 09:30 PM
Formerly ScreamingL
saw as high as 27psi for a short run but makes passes at 24-25 psi
20* timing 11.4 afr on E85
Old Jul 15, 2015 | 06:41 AM
Gadgetized's Avatar
Wow, that's really making some power. I will more than likely stick around 14-15 degrees. My build will be very similar. I see that you did rod bolts too. If you were doing it over would you do the rod bolts again? That was about the only thing I hadn't planned on.
Old Jul 15, 2015 | 09:01 AM
Formerly ScreamingL
for 80 bucks why risk anything....
it was tuned off plugs using Br7efs
14-15 is leaving alot of power on the table if using e85 especially at lower boost levels
14-15* is a good 93 timing number
but in the end youll need to read plugs to know how much timing to push or cant push...the setup didnt use knock sensors either
Old Jul 15, 2015 | 09:32 AM
Gadgetized's Avatar
Ok, I Have rod bolts on their way.
14-15 is what I was thinking on 93 @ 15 PSI and on E85 @ 22 PSI. Hopefully I can get this together soon.
Old Jul 17, 2015 | 12:48 PM
Mike454SS's Avatar
Are you going to run meth with the 93 or just pure 93? I wouldn't run much more than 14-15 on 93 at 15 PSI without meth.
