Request for an HPTuners file for 6.2 with tvs1900 or tvs2300
Old May 11, 2013 | 10:23 AM
MStefak's Avatar
Default Request for an HPTuners file for 6.2 with tvs1900 or tvs2300
I am looking for an Hptuners file for an 07-08 magnason supercharged 6.2 ... any help would be great im having a very hard time find this.
I am in need of the injector data for the 07-08 with 12613412 injectors magnason sends with the new kits.
Thanks guys ...
Old May 11, 2013 | 03:39 PM
kbracing96's Avatar
You would be better off getting with a mail order tuner who uses HPTuners. Most privet guys don't really like to share there tune's cuz they are specific for there setups. A mail order tuner can build you a good base tune to start off with specific for YOUR setup and will usually work with you to help iron it out. And there are usually only a couple hundred bucks.
Old May 11, 2013 | 11:39 PM
JCunningham's Avatar
are you doing your own tuning? if not get a dyno tune. I had a very good data log tuner do mine and it was not very great. I just got a dyno tune and gained 59hp over the data log tune. my dyno tune was $500 and worth every penny.
Old May 12, 2013 | 09:05 AM
smdusaf's Avatar
same in my experience
Old May 12, 2013 | 09:48 AM
03sierraslt's Avatar
As everyone has pointed out, each tune has to be built specifically for each setup. There are constant variables such as injector values etc but everything else is going to vary. If you are only looking for the injector values then thats fine but dont count on anything else. Based on my findings that is a 40lb injector, which is pretty small for a blown 6.2
Old May 12, 2013 | 01:18 PM
40lbs will not work on a 6.2l. use the stock 50lb injectors. there ok for 6psi. im at 8psi and my IDC is 98%. Magnuson sent 47lb pink injectors with mine and they were to small.
Old May 12, 2013 | 10:41 PM
MStefak's Avatar
I do custom tuning . what im requiring is the data for the 12613412 injectors ( stock flex fuel injectors, LS9 injectors and the ones maggie sends with the new kits now )
My issue is that 09 up ecms use a different pressure delta table then the 07-08s so the data does not over lap and I cannot calculate the difference.
Im truely after the injector data for these injectors that has been inserted into a 07-08 .
Thank you .
Avalanche2002
Nov 30, 2015 07:31 AM
dantheman1540
14
Sep 28, 2015 09:22 PM
97_ek
Sep 23, 2015 09:16 PM
MikeD.
Sep 18, 2015 09:55 AM
