Reading boost on NNBS?
Old Oct 15, 2010 | 09:49 AM
bdubb's Avatar
Default Reading boost on NNBS?
What are you guys doing to read boost on your NNBS trucks?
With my aeroforce gauge I can read from the stock MAP but it only appears to read to +0.7 PSI. Just curious what others are doing.
Thank you
Old Oct 15, 2010 | 10:58 AM
Bluchevypick's Avatar
Buy one of the vacuum manifolds from notwothesame.
He has them listed in classifieds.
Old Oct 15, 2010 | 11:41 AM
Atomic's Avatar
I have a gauge for that
get a real boost gauge and hook it up to a vacuum port...or to do it electronically you would need an electronic sender and plumb it through an unused port in the PCM or something...or an AUX input on hptuners or efilive.
Old Oct 15, 2010 | 11:55 AM
BigKID's Avatar
You stock MAP senosor is only good to 1bar or atmospheric pressure. You easiest solution is going to be to get a sending unit or 0-5V MAP sensor and use and aux port on your scan guage. http://www.aeroforcetech.com/product...ors_boost.html However, you will not be able to read this with scanning software (HPT, EFILive, ect) unless you have an enhanced version if it what allows a 0-5V aux input.
Old Oct 15, 2010 | 07:17 PM
skipperdaddy's Avatar
Or get a tmap from a cobalt ss, its my understanding that using that will let u read boost thru the pcm via, scan tool, egde/msd dashhawk multigauge display...
Old Oct 15, 2010 | 10:02 PM
BigKID's Avatar
The cobalt map will only work if the pcm is running an OS that knows what to do with it, i.e. 2bar SD OS. I don't know of any custom MAF OS that uses a 2bar MAP table.
GXPJAY
Feb 13, 2022 08:15 AM
chopperloco
Jul 10, 2016 10:45 PM
JordanH
Aug 8, 2015 07:59 PM
RS/SS 4.8
Aug 2, 2015 11:03 PM
chvy=power
Jul 27, 2015 10:06 AM
