Radix rotor coating & meth
Old Apr 21, 2006 | 02:54 PM
  #31
thunder550's Avatar
High on diesel fumes
I can see it interfering with airflow a little, but if the restriction is not in the intercooler, it would just push a higher volume of air through a smaller opening. Once you hit the point where the clogged intercooler became the restriction, then you might start to lose manifold pressure.
If you look at the pics of the head unit it looks like the bypass valve circulates air from just below the rotors back into the intake piping...and as long as the meth was set to kick in under boost and not vacuum, the bypass valve would be closed anyway....unless I am missing something. Maybe Brian can explain further how that might work. All the pics below are from this article: http://www.popularhotrodding.com/tech/MagnaCharger/
I dunno, maybe it's not possible to make something like we are talking about, but I think this is good discussion about whether or not it would be possible.
Old Apr 21, 2006 | 04:15 PM
  #32
TG02Z71's Avatar
So what type of coating is it and what is the job of the coating?
Is there a different coating that could be used, like lets say hard-coat anodize? Not the color pretty anodizing that is used to make things look pretty.
Old Apr 21, 2006 | 04:32 PM
  #33
BlownChevy's Avatar
blownerator
25 Year Member
The coating is an abradeable powder coat (APC). It is there to take the clearance between the rotors and the rotor housing down to almost 0. the rotors actually "hone" or "wear" into each other creating a nice tight seal.
Old Apr 21, 2006 | 05:57 PM
  #34
vanillagorilla's Avatar
Dude, there's plenty of room there. Now, what's the heat exchanger made out of? Aluminum? If so, that poses a problem too.
Old Apr 21, 2006 | 05:58 PM
  #35
thunder550's Avatar
Why does that pose a problem?
Old Apr 21, 2006 | 07:04 PM
  #36
04Denali's Avatar
I would think that the meth would corrode it over time.
Old Apr 21, 2006 | 07:10 PM
  #37
thunder550's Avatar
The heads are aluminum too, and nobody has had problems with the heads corroding that I have seen...
Old Apr 21, 2006 | 07:16 PM
  #38
dewmanshu's Avatar
Moderately Differentiated
I can't imagine why you'd ever have issues with aluminum and meth/alcohol. Now nitrous on the other hand..."the Oxidizer".
So whatcha think, putting nozzles in the intake tracks or doing a dual nozzle scenario with the fuel injectors?
Old Apr 21, 2006 | 07:20 PM
  #39
Bill Reid's Avatar
Direct port meth
Old Apr 21, 2006 | 07:31 PM
  #40
kbracing96's Avatar
Meth corroding it is BS. Sprintcars and indycars run 100% meth for fuel on ALL aluminum motors with no corrosion issues.
And to add to this, you are talking about a very small about of meth and only in short burst. Its not there long enough to cause any harm even if it was that corrosive.
