Radix not performing at track.
Old Oct 1, 2007 | 09:38 PM
Yellowsierra's Avatar
Originally Posted by CashDudeHomie
I suppose it could be slipping some, but I didn't notice any belt dust under the hood, like some people with slipping belts have mentioned.
If you have KR its probley either running to lean or to much timing. Say your running 17deg timing advance and have 7 deg KR. The KR is subtracted from the timing so its actually only runing 10deg Timing advance. You may be able to knock the timing down to 15deg and have 0 KR which is beter than having 17deg advance and 7deg KR. As far as the air/fuel ratio goes you wait to be somewhere between 11.3-1 to 11.8-1 @ WOT. I dont know if you have a wideband to measure this with but if you do thats where you want to be. If your reading off you 02's you need to be running Atleast 900mv @ WOT. Your 02's are really not to accurate and I recommend hooking it up to a wideband to get a good reading. Like everybody said its probley all in you tune. Youll be surprised what a difference a Good tune can make compared to an ok tune. I wouldnt be surprised if you got a good tune went back to the track and ran 105+mph.
Old Oct 1, 2007 | 09:41 PM
thunder550's Avatar
High on diesel fumes
This is the Magnuson superchips engine tune, with adjusted idle and transmission tables by myself.
So you're saying that you're still running the Magnuson supplied VE, PE, and timing tables? With an aftermarket cam, small pulley, and high stalling converter? If so, you need to get a custom tune in that thing ASAP! It's probably running really lean up top, which is why you're seeing a ton of KR.
MikeGyver's Avatar
What does 2.9 inches translate to in psi?
Old Oct 1, 2007 | 09:42 PM
thunder550's Avatar
Should be roughly 6-8 psi depending on the cam.
Old Oct 1, 2007 | 10:01 PM
MikeGyver's Avatar
You need a wide band.
Old Oct 2, 2007 | 12:48 PM
CashDudeHomie's Avatar
Thanks for the posts. The O2 mv thing is really helpful. I'll try to figure out why they're so low. I'm still a noob at this tuning stuff
Old Oct 2, 2007 | 04:22 PM
BlownChevy's Avatar
blownerator
25 Year Member
At this point I think a nice dyno tune is in order.
Old Oct 2, 2007 | 05:36 PM
ZZebes's Avatar
Dude you need a real tune before you pop your motor
Old Oct 2, 2007 | 09:19 PM
BigTex's Avatar
Originally Posted by Yellowsierra
If you have KR its probley either running to lean or to much timing. ...
First adn foremost, he has a 1999 truck with pretty high miles and 99 the PCM is still installed (I believe). For us old timers who've been around a while, you'll remember the 99 truck PCMs were HORRIBLE dealing with knock retard and timing. I am so glad I'm not still dealing with my old 99 truck.
What he really needs is to get an 02 PCM/tune with the Magnuson superchips loaded on it than begin tuning from there.
Old Oct 2, 2007 | 10:26 PM
BlownChevy's Avatar
blownerator
25 Year Member
good memory....I almost forgot about that. I agree with you, he needs to start out with a base calibration from magnuson and tune from there.
