Radix Gates Tensioner & Steel Pulley Numbers
Back in March you stated that you couldn't find a green belt in a 6 rib. They offer many more sizes available in 8 rib, and you can easily cut off 2 ribs with a razor blade and have a 6 rib belt in the length you need.
If anyone was looking for the part number for the 100mm idlers and couldn't find them, the part numbers listed earlier in this thread are wrong. I cross referenced the Gates catalog just to be sure.
100mm idlers - Gates 38002
Amazon.com: Gates 38002 Belt Drive Pulley: Automotive
My Type-o, Sorry Folks! Thanks! I fixed it in the OP. Can you edit your post to reflect?
Thanks Again!
Does anyone know how much more belt length i will need going from the 90 to 100mm idlers? I am currently using a Gatorback 6 rib 110.5. Hoping to find a Gates belt in a similar length and give it a try.
I am running a 2.8 inch blower pulley on an MP122 and getting a little slip at high rpm. Thx.
lxcoupe
13
Nov 20, 2015 08:43 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
