Radix - belt/pulley squeak
Old Mar 15, 2009 | 01:22 PM
gdev_'s Avatar
Default Radix - belt/pulley squeak
First of all, I had my kit installed, so pardon my ignorance.
I've had this squeak that has been getting progressively worse since the kit was installed, about 2000 miles ago. I had done some looking in the past, and it appeared that one of the pulleys wasn't aligning properly, but even going back over the install instructions, thought it all "looked" right. Well, it's been getting worse, so I dug back in. Here are a couple pics of what I found. Surely this cannot be how the bracket is supposed to be.
Sorry about the quality of pics. Could this be the cause of my squeaks (and why the belt hangs off the back of the pulley 1/8")? The bearing couldn't possibly be flush against the mount with the "lip" that is there.
Old Mar 15, 2009 | 05:31 PM
gdev_'s Avatar
NM, Fixed it. That was indeed the problem. Looks like when the pulley was installed that the bearing wasn't seated on the mount, and when it was tightened it took the top off and under. Filed it off and it seems to be ok.
I'm quite sure that was what was behind my previous belt rubbing issues.
Old Mar 15, 2009 | 05:59 PM
BlownChevy's Avatar
blownerator
25 Year Member
someone done fugged that install up. Glad you got it fixed!
tim wellington
Sep 29, 2015 10:17 PM
bagged7104SS
Sep 24, 2015 08:42 PM
97_ek
Sep 23, 2015 09:16 PM
the owl
Sep 4, 2015 04:09 PM
sTNT971
Jul 16, 2015 12:39 PM
