quick help with fuel system direction
Old Sep 20, 2010 | 07:59 AM
jetttstream's Avatar
Default quick help with fuel system direction
Hey guys. Running a 370 with a D-1SC procharger. Deka 60s (~73lb/hr @ 4 bar).
I'm converting to a return system, currently returnless
My GSS341 HP can't keep up, on my returnless setup pressure drops enough to make me not floor the truck in like 3 months.
My choices are DIY dual walbro's. I have the pumps, I have the harnesses. I was even going to have a THIRD walbro to just pour fuel on the bucket when in boost. (2nd in-tank/bucket turns on in boost as well).
Seems complicated, but offers the most 'stock' sound and performance/reliability..although with 3 pumps there is a large margin for error.
Next choice:
Stock pump Y'd into a magnafuel 4301 (will turn on at 2-4psi) that is sumped from rear side of tank (not bottom--I drive in the snow and don't want anything dragging underneath).
-8 or -10 feed goes into a Y with dual checkvalves (one side is coming from stock walbro, other side is incoming from magnafuel), and feeds the rails.
I am using an aeromotive 13109 rising rate FPR as well. -6/stock feed as return to bucket.
The 3 walbro's are cheaper than the 1 magnafuel. I guess I just don't know which direction to go in. The Magnafuel seems a LOT less complicated at this point.
Any insight or push toward a selection appreciated.
-Mike
Old Sep 20, 2010 | 08:21 AM
Atomic's Avatar
I have a gauge for that
bosch 044 in tank with 10ga wiring.
Old Sep 20, 2010 | 08:32 AM
And that is really enough? I've considered it. A friend of mine ran a 044 and 255 walbro and couldn't keep up the pressure. The 044 was mounted exterior. With his Magnafuel setup now he has no issues making fuel pressure.
RONIN LSX
Aug 10, 2015 04:45 PM
TAPyvehc93
Aug 8, 2015 06:35 PM
MS3Z
Jul 30, 2015 06:17 PM
4B11T
Jul 13, 2015 03:48 PM
