Pulley size and boost levels
Old Apr 7, 2018 | 12:56 PM
  #61
Littlefield's Avatar
Originally Posted by Littlefield
2016 Silverado 1500 5.3l, Whipple 2.9, 4 3/8 pulley, LT TSP 1 7/8” headers, catted Y pipe, stock exhaust except for Carven TR muffler. Pat G online tune is much improved over Whipple tune. I’ve seen 9 psi in the scan gauge. A little surprised it’s that much. Exhaust may still be restrictive at higher RPM’s.
Installed a Carven progressive cat back system with a Vigilant resonator. Maximum boost is now about 8psig.
Old Apr 11, 2018 | 05:27 PM
  #62
jstev4610's Avatar
just logged my new setup
2015 5.3 with tvs1900, kooks longtubes and catted y pipe, carven catback. Stock pulley.
3.9psi
anyone know a real world psi gain from a griptec of the same size? The log doesn't look like I'm slipping so maybe nothing? I want to get it back up around 5.5 psi. If I get a griptec and pulley down .2, is that getting me where I want?
Old Apr 12, 2018 | 10:15 AM
  #63
Vortec350ss's Avatar
If its the same size you wont see a gain.
Damn that boost is low!
Old Apr 12, 2018 | 11:04 AM
  #64
flatblack83's Avatar
Stock pulley tho meaning 3.4 or 3.7..? If I remember correctly... My old 1900 came with a 3.7 i had 4 psi, with the 3.4 I might of had 6.
I know my stock 6.0 to my 408 with a 2300 I see 2 psi in the difference. I had 12 psi, now see 10. That's with a grip Tec 3.2 8 rib.
Old Apr 12, 2018 | 01:31 PM
  #65
Matt24's Avatar
3.9psi
I have pretty much the same setup except I dont have cats. With a 87mm(~3.4) pulley I was around 5 psi. That was the pulley my tvs1900 came with. I pulley'd down to a 81mm(~3.2) and seen around 8 psi. Look at the back of the pulley, magnuson puts their sizes in mm. Ill sell you the 81mm if you want I went to a smaller pulley again.
Old Apr 17, 2018 | 06:38 PM
  #66
jstev4610's Avatar
3.9psi
I put Matt's 81mm pulley on, stock was 87mm. Boost is up to 6.6 at max, bigger change than I expected. Going to call it good here.
Old Apr 25, 2018 | 12:48 AM
  #67
dantheman1540's Avatar
Ive got Flatbalck83's old tvs1900 with a 3.4 on my stock 4.8 with long tubes and a LS2 throttle body. I also have a full length exhaust with NNBS muffler and resonator but I have a Cutout were the y pipe merges. With the cutout closed I see 6-7psi with the cutout open I see 5-6psi.
Got a griptech 2.8 coming this week. =D
Old Apr 28, 2018 | 06:30 PM
  #68
I was actually wrong before I thought I remembered the original pulley was a 3.4 it was actually a 3.7.
Just installed my griptech Level 3 2.8 6 rib pulley and I am seeing 13psi. Its a whole new animal couldnt be happier!
Old May 1, 2018 | 01:01 PM
  #69
CHRGDUP_Denali's Avatar
I have an 08 sierra denali 6.2 with a tvs1900 and 3.1 pulley (3.1 came with kit). When i first installed it, truck was completely stock with blower and made around 6psi. I now have 90mm TB, 1 7/8 longtubes, and dual 3" exhaust and boost dropped down to about 5psi. Wondering where yall think i would be at if I install 10% overdrive pulley and 2.8 blower pulley? hoping for around 10psi.
Old May 14, 2018 | 09:04 PM
  #70
smokinlmm's Avatar
I'm thinking of the same setup. Power bond overdrive crank balancer and pulley down to the 2.8 myself. Just thinking I should go ahead and go 8 rib trying to make 12 to 14 lbs...
