Pulley size and boost levels
Old Dec 7, 2017 | 06:29 AM
  #51
trxmxzx's Avatar
13 Second Truck Club
I will add to the list
5.3 milled 862 heads (.032)
tr220-112 lsa
1-3/4 pacesetters with ORY - single stock pipe through hooker areochamber
cai
mp122- 3.1 pulley
8 PSI
Old Dec 7, 2017 | 12:28 PM
  #52
smokeshow's Avatar
Mod with training wheels
5.3 and a 1900...2.9x pulley
Old Dec 7, 2017 | 12:44 PM
  #53
Vortec350ss's Avatar
Cheater.
Wanna tell us how much boost it was being fed???
Old Dec 7, 2017 | 12:47 PM
  #54
smokeshow's Avatar
Haha. I wish there was a turbo in front of it. This is just some wonkyness from the bypass valve actuator, actually... I don't have full control over it yet. Long story short, the blower inlet area actually became pressurized and started compound boosting its own boosted air, resulting in a spike. Never seen anything like it lol.
Old Dec 7, 2017 | 01:15 PM
  #55
whaaaaat... that is bizarre!
Interesting that IAT didnt rise and I assume it was while letting off? Airflow is decreasing. I am having a hard time understanding how that even happens...
Old Dec 7, 2017 | 01:40 PM
  #56
smokeshow's Avatar
It was a spike, very brief...no real time to build up heat. Airflow was decreasing because pressure behind the throttle was above baro, so MAF flow nearly stops. I was only going a couple miles an hour pulling away from a stop, just a little bit of throttle. Manifold pressure came up and opened the bypass to control boost while throttle position was decreasing. With the duty cycle on the solenoid where it was, it was enough to allow the bypass pressure release behind the closing throttle to rise enough to close the actuator again, reboost that air and continue the vicious cycle. In figuring this out I had seen it cycle like that as many as a half dozen times. That time I was driving maybe 35mph and IAT went up like 40 degrees in just a second or two. This was the worst instance I had seen though in terms of overboosting, thought it was pretty funny lol. Crazy when your SCIAP sensor reports 106kpa and you don't have a turbo. Don't try this at home, kids.
Old Dec 7, 2017 | 02:05 PM
  #57
TXsilverado's Avatar
I doubt anyone here can use my data...but:
408CI
ls3 top end
10.5:1 comp
0 overlap cam
kenne bell 3.6
4" pulley makes about 12 lbs.
Old Jan 8, 2018 | 04:16 AM
  #58
crutt's Avatar
2010 5.3, stock heads,stock lsa supercharger, 1 3/4" headers/offroad y, 8 psi-ish
Old Jan 11, 2018 | 02:56 PM
  #59
shortshifted's Avatar
GM TECH
2011 SILVERADO CC/SB 4WD
FACTORY 6L80E TRANS
9.5" DETROIT TRUTRAC
3.73 GEARS
LYSHOLM 2300AX W/ 3.25" PULLEY
LS9 HEAD GASKETS
ARP MAIN/HEAD STUDS
WISECO FORGED PISTONS W/PIN
UPGRADES-FACTORY BORE
W/ K1 RODS - GM CRANK
BTR STAGE 2 TURBO CAM
COMP PN#32631134
COMP ADJUSTABLE TIMING SET
COMP MATCHED DUAL SPRINGS
COMP HARDENED PUSHRODS
COMP SHORT TRAVEL LIFTERS
COMP TRUNION ROCKER UPGRADE
VVT & DOD DELETE
CAMARO THROTTLE BODY
RAND MCNALLY DUAL VALVE PCV
SNOW DUAL METH NOZZLES (2x #5'S)
---CURRENTLY ON@3PSI - FULL@6PSI
KOOKS 1 7/8 LONG TUBES
W/3.5" CATLESS MBRP EXHAUST...FIRSDT TUNE WAS HORRENDOUS
NARROWBAND TUNED AND IN PROCESS FOR NOW WITH A NEW AEM WIDEBAND, 2.5 BAR MAP.
RUNS JUST UNDER 10 PSI NOW...RAN OUT OF INJECTOR ON STAGE 2 MOPARS - NEED SOME ID 850's BADLY
Old Mar 29, 2018 | 09:00 PM
  #60
Littlefield's Avatar
2016 Silverado 1500 5.3l, Whipple 2.9, 4 3/8 pulley, LT TSP 1 7/8” headers, catted Y pipe, stock exhaust except for Carven TR muffler. Pat G online tune is much improved over Whipple tune. I’ve seen 9 psi in the scan gauge. A little surprised it’s that much. Exhaust may still be restrictive at higher RPM’s.
